*sigh* Timing issue
Car: 1991 Firebird
Engine: 305 TBI
Transmission: Automatic
*sigh* Timing issue
I can't seem to find the metal peice with the timing degrees on it. stock 305 engine. I had no problem finding it on my 2.8 bird, but this one, it leaves no trace. Perhaps I'm looking in the wrong place, but if anyone has a pic of where I should look, if its hiding, would be great.
edit*: peice/piece its all the same if you glance quick enough
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
on my 305's if you look behind the waterpump stright down it is right there. Ussually that is where they are on most.... not there.then perhaps it broke off?
yea. not exactly something that happens very often in fact i think it is rare.. but it is ussually affixed to the timing cover. If it is not there then it took a trip without you.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It may have fallen off as mentioned but I bet if you got a flashlight and really leaned over and looked behind the water pump you will see it. Chances are it is rusty and full of funk thus making it not stand out. A little sandpaper wrapped around a long screw river is often times enough to clean it off so that it is legible. You should also consider using a little white paint to fill in the line on your harmonic balancer. These two tricks alone can make setting your timing a lot easier. Especially if the lighting outside is poor!
theshackle
Sep 17, 2020 08:26 AM
