new to engines
Old Sep 29, 2006 | 05:07 PM
newRSdriver's Avatar
Car: 90 RS
Engine: 305 TBI
Transmission: 5-speed
new to engines
I am wanting to replace my stock engine for a new one soon. I have a stock 90 camaro rs, 305 carb. It is my everyday driver and i want to keep it like that. where can i search to find engines that are good for everyday use?
Old Sep 29, 2006 | 05:53 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Welcome aboard!
Why do you want to replace your engine? More power? Is it worn out?
Before you swap engines you should write down what you want out of the car.
Fuel mileage, power, use of vehicle, mileage, and budget should all be considered. Defining what you want out of your motor will help us and you determine what is a good fit to match your goals. You may find that your current motor can do exactly what your intended goals are.
Are you sure it is carb? A stock 1990 RS V8 car was equipped with TBI which, although looks like a carb, is actually fuel injection.
Old Sep 29, 2006 | 07:28 PM
Car: 90 RS
Engine: 305 TBI
I believe you are correct. It is a 90 rs TBI. the stock engine is starting to get high milage and i am also looking for more power but since it is an everyday driver i do need good gas milage. I do have a low budget and I am trying to keep myself money.
Old Sep 29, 2006 | 10:32 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Originally Posted by newRSdriver
I believe you are correct. It is a 90 rs TBI. the stock engine is starting to get high mileage and i am also looking for more power but since it is an everyday driver i do need good gas mileage. I do have a low budget and I am trying to keep myself money.
How many miles are you approaching on? It is very common for TBI motors to see 200K+ miles and run fine. As a low power, low RPM, and simplistic parts motor they tend to last for a very long time. If you want to add some more power a few simple things such as intake and exhaust mods can add a quick 25+ hp. Check out the "new to TBI" sticky located at the top of the forum for more details on modification specifics.
Old Sep 30, 2006 | 05:04 AM
DM91RS's Avatar
Car: 91 RS
Here's one at 212,000 miles with the stock shortblock and T5
One thing I have done since it's high milage and a daily driver is rpm limit it to 5k.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
