TBI: I want to keep my ignition and use EFI for A/F metering ONLY
Old Oct 11, 2006 | 10:36 PM
EvoTech1's Avatar
Car: Beater 66 442 clone DAILY DRIVER
Engine: stock 400
Transmission: TH-400
Axle/Gears: 12-bolt posi 2.73 14.71et
Ok, can you lock out the timing function and use a TBI and ecu on a carbed application to meter air and fuel accurately independant of timing? Or is the timing control needed for attaining an accurate a/f ratio?
I am asking this as I an looking at using a TBI setup on an application where there is no TBI distributor available. Ive heard modding the existing distributor works, but its seems complicated.
Old Oct 11, 2006 | 10:42 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Are you trying to put TBI on the Cutlass in your signature? If so, just use a CCC HEI from a mid-late 80s Olds 307.
Old Oct 12, 2006 | 10:32 AM
EvoTech1's Avatar
Engine: stock 400
cool cool, but i like the TBI so much, were thinking about the possibility of using one on my friend's toyota pickup. He has a rebuilt 22r with towing cams, a ported, milled head, and a full exhaust. It is pretty strong, and has great midrange, but he hates having to adjust the carb when the weather changes.
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
Gunner242
Dec 25, 2015 04:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
sahlomonic
Sep 20, 2015 07:15 PM
