Welcome back everyone!
Old Sep 10, 2000 | 09:20 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
now lets get back to where we left off, discussing ways to make more power!
As an update, im now sporting a t5, 3.42 gears, and its tuned pretty well with the pathetically small throttle body. I plan on boring the stock throttle body to 48mm which is the size of the stock tpi throttle blades. As it stands now im seeing 1" of vacuum by 4800 rpm. But it still revs to 6k no prob.. peak power is around 5300 or so
anyways WB
Old Sep 10, 2000 | 09:29 PM
z28wiz's Avatar
good to see the site back up
91 RS' TBI 305
mods:
dynomax exhaust, lakewood control arms, gutted cat, pioneer deck, tbi spacer, jet stage 2 chip, K&N four inch element and open element, accel cap and rotor, moroso plug wires, msd blaster coil, bosche +4 spark plugs. Alot more mods to come!!
visit my page http://www.geocities.com/motorcity/pit/8410
Old Sep 10, 2000 | 10:09 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
sweet..i have ben waiting for long enough.
1991 Camaro RS
Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Performer Vortec Intake, Holley 670 CFM Throttle Body, Open Air Cleaner, Edelbrock TES Headers, Edelbrock Victor Series Water Pump, Accell Superstock Wires, AC Delco Rapidfires, 3" Cat Back
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit
Brian's 1991 RS
Central NY F-Body Association
Old Sep 10, 2000 | 11:13 PM
jptaylor2's Avatar
pablo im having trouble getting my engine to run like it should. ive got a 400 ci with big valves and good high flow heads. im running a 670 holley and full length jet hot coated headers, underdrive pullies,no a/c or smog,k&n, accel super coil and 8.8 wires. the o2 is on but is way down at the collector and i know its not getting hot enough. it just feels weak, weaker than the 305. could my stock chip be holding me back that much. also i would love to put in a heated o2 but the ASE guys around here say that the 02 lead is a shielded wire and cant be spliced.
thanks
jptaylor
Old Sep 10, 2000 | 11:19 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
you can splice the wire, ive seen it done
definately puta heated o2 in and monitor what its doing
do you have the stock chip
also what cam do you have?
if you are running the stock chip forget about it making any power
Old Sep 11, 2000 | 04:23 AM
SVT99
Guest
Posts: n/a
podunk
Currrently:
1999 Ford Contour SVT
Formely:
1987 Trans Am 305 TPI (KrakeN)
1995 Trans Am 350 LT1 (LT1FireChickeN)
"Man Im not too good at mechanics but you just send me in and i'll do what I have to do cause you know im like a gorilla" - Yasser (Circa 1999)
Old Sep 11, 2000 | 11:18 AM
Tallboy's Avatar
great to see board up again
anybody know where I can get some valve seals
GOOD ONES...
or know of some tests to run,to check if car is leaking from valve seals...?
Old Sep 11, 2000 | 02:00 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
do you see a puff of smoke on startup?
if its bluish/grey
then its your valve seals
get the umbrella syle seals.. late model motors all ahve em like 91-92
and SVT99.. get back to driving your mercury topaz
Old Sep 11, 2000 | 02:07 PM
Tallboy's Avatar
Pablo,Id say its more white than blue....if any at all
yes there a lot on startup
and sometimes after idleing
I dont have a cat,and I have taken out my AIR system...I get a code 32...
maybe I should block the EGR valve?
if its the rings,id rather just go look for anotha 305...
maybe find an l69
what had the L69 heads anyway?
Fronzizzle
Mar 18, 2019 08:29 PM
db057
Aug 22, 2015 08:17 PM
86IROC112
Aug 21, 2015 07:20 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
