Pablo, more on my 400 delema.
Old Sep 11, 2000 | 09:05 PM
jptaylor2's Avatar
the chip is the stock chip from my original 305 tbi. the cam is a stock l98 piece. just to stay on this page ill run down my specs.
400 ci
l98 cam
jet hot coated flowtech full length headers
full 4" exhaust
underdrive pullies
accel super coil
8.8 wires
open element
K n N
holley 670
relocated iat
no smog
no air
stock 3.23 rear end
o2 at collector(needs to be heated)
let me know what you think
thanks
jptaylor
Old Sep 11, 2000 | 09:42 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
hmm
where is your base timing set? and which injectors are you running?
Old Sep 11, 2000 | 09:51 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
btw you say at wot its totally weak or part throttle?
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
basically tell me everything its doing or not doing
Old Sep 12, 2000 | 12:21 AM
jptaylor2's Avatar
alright,
the motor is set at at 6 deg base timing. the motor feels very weak out of the hole but does pick up as the motor revs. used to with my modded 305 i could smoke the tires until i let off, now im lucky if i even get a chirp. i first got the 350 holley 670 but it was way too rich even with the fuel pres. at 6 lbs. i sent it back and got the 305 holley and it really helped, now the pressure is at 13 lbs. if it is the chip do you know of anyone that can help. i talked to fastchips and they acted like it was a hassle for them to take my money. they didnt want to know about my motor,cam,heads,nothing. performance resource was the same way. i know that burning your own is the way to go but i dont have the equip.
thanks pablo
jptaylor
Old Sep 12, 2000 | 12:55 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
it needs tuning (obviously)
the pump shot will definately be too small, and the injectors, if the yare 305 sized, wont be able to feed your motor. You need a custom chip. The equipment can be had for LESS than what youd pay to buy a chip from any of those companies, check out the prom board there is a post there detailing pretty much all you need to know to get started.
for now, definately bump up your timing, bring it up to about 12 degrees, it should feel alot better.. it will probably want even more than that
play around with the timing youll definately see an improvment there
your combo should lay rubber easily (obviously)
get an LED o2 meter, and watch what it does, and get a vacuum gauge and tell me what it idles at.
Hotrodboba400
Dec 10, 2019 07:07 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
