HELP! I put my intake manifold back on and I have a nut left over!
Old Sep 15, 2000 | 06:15 AM
Eggplant Jeff's Avatar
I removed the manifold because of a leak. I put it back on and I have a nut left over! I think it came off one of the manifold bolts (there are two candidates that have stud heads) but I don't have any parts that aren't attached???
Could one of you guys open your hood, and look at the intake manifold bolts and see what (if anything) is attached to the ones with stud heads?
Old Sep 15, 2000 | 06:50 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
that just means your car is lighter now
if its a nut id say it came off one of the studs.. car runs right? if so.. probably not important
Old Sep 15, 2000 | 09:21 PM
89RS355's Avatar
I wouldn't worry too much. But check the drivers side real close. There is the throttle cable bracket, coil, brake booster vacuum pipe, fuel line(s) hold down, etc. Also, the passenger side has an EGR braket, not for the egr itself but the electronics. I can't remember if that used a stud/nut or just sat under the regular manifold bolt. Hope this helps!!
Jerry
89 RS Lt Blue T-Tops T5
355 Crate, Compucam 2040
Pst Front Hotchkis Rear
Edle. TES 3" Flowmaster
Harwood hood, bla, bla, bla...
94 Z28, LT1 6M, Black
Most of the bolt-ons
Old Sep 16, 2000 | 06:54 AM
Got all that...
Throttle cable bracket bolts under one manifold bolt, and uses one of the two coil bolts. Coil is held on by two bolts.
Brake booster vacuum pipe acts as the fuel line hold down, it is held on by a nut to a manifold bolt/stud, but that nut is already in place.
EGR valve is held on by two nuts, but they're in place. EGR bracket goes under two manifold bolts. EGR solenoid is held to the bracket by a screw.
The only thing I can think of is this nut wasn't holding anything down, but I think I would have remembered removing it if that were the case!
Old Sep 16, 2000 | 10:40 AM
Scott C's Avatar
How about the AC bracket/brace at the front of the intake? That has a nut.
'92 RS, ZZ4 10:1 350, Edelbrock 6085 heads, Crane 208/214 467/482 cam, GM 1.6 true roller rockers, Holley Projection TBI intake, Holley 670 TBI, SLP/Jet-Hot 1-5/8" headers, Catco 3" cat, Flowmaster 3" catback, Hughes 2500 stall converter, stock 700R4, Auburn Pro posi w/3.42, 17x9" SS rims w/BFG tires, Medium Quasar Blue w/white SS stripes, 48,000 miles....
Old Sep 16, 2000 | 12:48 PM
Yup Scott, got that one. In fact I think that nut is bigger than the left-over one (this is the same size as the two for the EGR and the one for the vacuum tube for the brake booster).
1992 Trans Am
May 10, 2023 07:19 PM
86IROC112
Aug 17, 2015 02:00 PM
st.evel07
Aug 13, 2015 06:15 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
Jake_92RS
Aug 11, 2015 10:39 AM
