350 buildup to replace tired 305
Subscribe
Nov 5, 2006 | 12:25 PM
Well i'm planning on swapping my tired 305 for a new rebuilt 350 and was just posting here to see if anyone had any opinions or suggestions on better parts that i could use in the process. The block i going to rebuilt is a 350 4 bolt main out of a early 90's p/u since those are readily available in my area (<3 Texas trucks).
Heads - Edelbrock Performer Aluminum Heads
SB-Chevy 302-400ci Performer Centerbolt Aluminum Cylinder Head
165cc Intake Ports
60cc Combustion Chambers
2.020'' Int/1.600'' Exh Valves
1.460'' Valve Springs, .575'' Max Lift
3/8'' Rocker Studs
Intake Manifold - Edelbrock Performer T.B.I. Intake Manifold
Cam - Edelbrock Performer-Plus Camshaft
Duration Advertised268° Intake/288° ExhaustDuration @ .050''194° Intake/214° ExhaustLift @ Valve.398'' Intake/.442'' ExhaustLift @ Cam.265'' Intake/.294'' ExhaustLobe Separation Angle112°Intake Centerline107°Intake Timing @ .050" Open 10° ATDC
Close 24° ABDCExhaust Timing @ .050" Open 44° BBDC
Close 10° BTDC
Throttle Body - Holly Pro-Jection Throttle Body
TBI Assembly
For 2-bbl Pro-Jection
670cfm
Reply 0
Subscribe
