Which ecm for a novice??
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
hey guys. Ive had tunerpro-rt and winaldl for almost a year. ive spent alott of time looking at various posts in here and this spring i want to jump into chip tuning on my 92 l03.
the motor is not staying in the car permanantly but it is going to stay for the summer. if i grenade it on a bad tune im not too worried.
i'de really like to use the prominator to accomplish the tuning however as i see the stock l03 ecm to be inferior im picking up a newer ecm.
The question is, should i go with the p4's you guys have been picking apart or are they beyond a novice tuners ability, if so would an older ecm work better in my case? or have you guys hacked the p4's enough that i could get it to work with a minimal learning curve.
id like to get my feet wet in the summer and then a motor swap should be in the works for next winter while she's parked, i plan on retaining the tbi. thanks alott
Car: 1983 G20 Chevy
Transmission: 4L60
I would go for a P4, running a TBI with a Mass Air Flow sensor. I am hitting the yards for my TBI bonnet and GM MAF in the morning.
Car: 1983 G20 Chevy
Transmission: 4L60
I would stick with a factory V8 ecm to make life more simple.
Many more features than other TBI ecms, including 8192 baud rate.
https://www.thirdgen.org/forums/tbi/...6197427-a.html
https://www.thirdgen.org/forums/diy-...-its-time.html
Car: 1983 G20 Chevy
Transmission: 4L60
No, they are still not that advanced. But one COULD swap to a 4L60E and control their transmission electronically, like I have done. I have been controlling my shifts with a piggy backed PCM for some time, then I moved completely over to the PCM. I am going to run the EBL with the new 3.1 TBI that I am dropping in when I get time. They are forcasting rain this afternoon and tommorrow, so that time has not come yet.
Car: 1983 G20 Chevy
Transmission: 4L60
You CAN convert a stock TBI ecm to "FLASH" chips to erase and reprogram them. The catch is you have to remove them from the ECM and put them in a Moates Burn 1 or similar to reflash them.
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
by running a maf would i be using it as data like a WB o2 or does it actually influence the ecm's tables as part of a hybrid MAF/SD setup? i have no experiance with MAF whatsoever. I believe my ecm allready has a tune in it as we suspect it to have been cammed and it runs too well to have been modded and not tuned (stock engine wit possible cam runs a 15.7 1/4) so i will be diggin myself out of a tuning hole i suspect(using a stock tune as a starting point).
So the p4 has been hac'd completely? i was reading that post on (its time to update) installing a p4 and it sounded like they hadnt figured it all out yet.
ide like to do the ecm/pcm swap this winter so i can be driving the car more then working on it.
i have a dual snorkel air cleaner would i have to run two maf's?. i've stared at the tables for my car in tunerpro alott and the p4 seems to eliminate alott of older features like low res spark/load/rpm tables but add alott of issues with passkey and such, is it worth it?
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
WHOA DADDY! i just finally figured out what the EBL was. seems to wrap up what im looking for quite nicely, combines aldltobin winaldl and alott higher performance ecm in one box! am i correct?? is this a good newbie move?? jezus i could not find an explanation of what the ebl was for like a week! thought it just hopped up the baudrate!
efiguy
Sep 27, 2015 01:30 PM
