Should I go TBI????
Should I go TBI????
I am really thinking about going to TBI rather than a 4 barrel holley or TPI. I have been told that the TBI setup is alot easier to work with than a TPI but I would want a 4 barrel TPI to feed the 383. Do you all think that it is worth it?
how much hp are you projecting out of this 383? the two barrel 670 tbi will support 350 hp easy if done right
i like tbi alot its like the high rpm potential, manifold selection, and tuning of a carb, but with none of the downfalls like low rpm/vacuum signal problems, hence better low end torque
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
U think those injectors that come with that Holley TB unit will be enough for a 383? I would think maybe 88lb injectors, flow matched.
rs_z28_vert
Sep 30, 2015 09:47 PM
