fuel pumps????
Old Sep 23, 2000 | 12:50 PM
NJ SPEEDER's Avatar
fuel pumps????
what kind of peak pressure is the factory pump capable of pushing? could i regulate it with an off the shelf low pressure (7-15lbs) regulator from a carburated car?
thanx
tim
91 Camaro RS-LO3,Auto.
15.217@89.38mph
Edlebrock TES Headers, Random Tech Cat, Borla Adjustable Cat Back,Marche Pulleys, HyperTech Chip,Transgo Shift Kit,B&M Convertor(2000stall), 36mm Front 25mm Rear Sway Bars, Eibach Pro Kit Springs, Bilstein Shocks and Struts, Steve Spohn Rear Rig( all rod ends), Poly Front Bushings, Baer Track Kit Front Brakes W/ Baer Disc Rears, 17x9 4th Gen SS Wheels, Ported TB, Edlebrock Performer TBI Intake, Performer Heads, 1.6 Roller Tipped Rockers
Old Sep 23, 2000 | 03:49 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
ive seen specs in some fuel pump catalogs that say 18 psi but i also know of people who have pushed them to 25 psi... i guess anything past 18 is at your own risk
Old Sep 23, 2000 | 08:30 PM
Kevin R 82 Z28's Avatar
It's not quite that simple.
Pressure is based on the pumps volume output which is then restricted by the regulator.
Looking at a graph from a Walbro 401 pump(for TBI). It can put out anywhere from 0 to a max of 38psi. Thing is, at 38psi it can only SUSTAIN approx 5gph or enough for 50-60hp depending on VE. On the other hand, at 20psi it's 28gph and at 10psi it's 34gph. So it kinda depends on the pump and how much hp you're making. On this particular pump I can run 18-20psi up to approx 280-300hp or 11-13 up to about 325-335. More than that and I'd be getting pressure drops at WOT.
For what it's worth, it's better to have a pump capable of handling more (20%) than you need for both performance and the life of the pump.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
