Guys, I need to re-locate my coil.
Old Sep 13, 2000 | 05:32 AM
89RS355's Avatar
My coil is not going back on my manifold. Have any of you re-located it? I notice Accell sells a remote mount coil that should fit the two connector late model GM coil. Just curious, where did you put yours, and did you have to run a ground strap to it, due to bad grounding at the new location? Thanks!
Jerry
89 RS Lt Blue T-Tops T5
355 Crate, Compucam 2040
Pst Front Hotchkis Rear
Edle. TES 3" Flowmaster
Harwood hood, bla, bla, bla...
94 Z28, LT1 6M, Black
Most of the bolt-ons
Old Sep 13, 2000 | 08:39 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Mounted mine on the driver side fender behind the strut tower near the relays. No ground strap needed.
Mongoose-NCTGA-1990 Pontiac Formula/305 TBI-700R4 with Edelbrock Performer TBI intake,TES headers,and STB,K&N,MSD-6AL,Holley laser shot coil,Accel Extreme 9000 wires,Jet Stage 2 chip,TCI shift kit with corvette servo,Richmond 3.73 gear with Auburn 3 series posi,no cat,SLP 3" cat back,Eibach sportline springs,Energy Suspension poly throughout,Lakewood LCA and adjustable panhard bar package,SSM subframe connectors,IROC wonder bar,Tokico 5 way adjustable struts and shocks,Autometer electric fuel pressure gauge,Alpine,JL Audio,MB Quart,92 GTA taillights,92 GTA aero wing and hatch,Steve Spohn LCA relocater kit,MacEwen White face gauges,84 T/A cold air induction air cleaner.
Old Sep 13, 2000 | 02:04 PM
Scott C's Avatar
I mounted mine on the firewall between the wiper motor and the brake booster. It fits perfectly and looks like it belongs there.
I hooked mine up using the supplied harness. There are red and black wire terminals for the power and ground, and the 8MM coil wire will plug into the distributor cap just like stock.
'92 RS, ZZ4 10:1 350, Edelbrock 6085 heads, Crane 208/214 467/482 cam, GM 1.6 true roller rockers, Holley Projection TBI intake, Holley 670 TBI, SLP/Jet-Hot 1-5/8" headers, Catco 3" cat, Flowmaster 3" catback, Hughes 2500 stall converter, stock 700R4, Auburn Pro posi w/3.42, 17x9" SS rims w/BFG tires, Medium Quasar Blue w/white SS stripes, 48,000 miles....
Old Sep 15, 2000 | 01:51 AM
Jza's Avatar
Jza
If you do mount it on the firewall, keep an eye on details like allowing for engine movement (since it's no longer moving with the engine) and that it should stay dry.
Although if you're not willing to have your coil on the manifold, is there any argument against getting the coil-in-cap version? Just a thought..
Old Sep 26, 2000 | 04:52 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
also a good idea if youre getting an open element. i put mine on and months later it rubbed thru the 12v into the coil and blew a few fusable links under the car. Just a reminder, it is on the bottom of the ultimate tbi article too. Just thought i bring it up with the topic.
Old Sep 28, 2000 | 02:04 AM
larsulrik's Avatar
Car: 1992 RS
Transmission: A/T
That's exactly what happened to me when I got my 14" open air. I thought it was ok to have it sitting on the coil slightly. One day I hit a big bump and literally everything went off. It took me a few days to realize the connection. The mechanic I asked before I found the answer told me that when newer cars hit a big bump they sometimes shut down, like a fuse, until you push the reset button. I spent all night looking for that damn button.
Derick15
Sep 17, 2016 05:28 PM
apo_bailon15
Mar 28, 2016 05:20 AM
transamgta1Khp
Aug 17, 2015 12:18 PM
Street Lethal
Aug 14, 2015 08:25 PM
