Engine stall (82 Trans Am)
Old Oct 2, 2000 | 03:16 AM
maverick's Avatar
Hi, I have a problem. The engine(CFI) stalls when the brake is applied for the complete stop. This problem usually occurs right after high speed drive. It's like, RPM goes down too much and stalls as I apply the brake. It doesn't give me any trouble code.
Any advice would be appreciated. Thank you.
Old Oct 2, 2000 | 04:00 AM
Twin_Turbo's Avatar
You need to raise minimum air. A good balancing of the TB's will do that. usually this problem is caused by the idle stop screws. Aftert opening and closing the throttle numerous times they wear and the throttle plates close too far. The ECM isn't fast enough to counteract this with the IAC motors. The ECM is just old crap but opening the throttle plates a bit solves this.
Go to The Cross-Fire injection vault for lots more info!
Marck
[This message has been edited by FAQman (edited October 02, 2000).]
Old Oct 2, 2000 | 11:00 PM
maverick's Avatar
Thank you, Marck !!
I'm looking into that.
BTW, the CFI site is great !!
mav
84z96L31vortec
Aug 20, 2017 12:16 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Sanjay
Aug 12, 2015 03:41 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Exxon Limited
Aug 9, 2015 08:13 PM
