Fuel Meter Cover - Is this normal?
Old Nov 9, 2006 | 09:52 PM
MavViper's Avatar
I'm having fuel issues. I am getting good fuel pressure up until the throttle body. I took off the fuel meter cover and when I looked in the pressure regulator I noticed something in the passageway. I am not sure if it is suposed to be there or not. Here's a picture of it:
Old Nov 9, 2006 | 10:09 PM
HiPerf_Chevyman's Avatar
Car: 1991 Camaro RS
Engine: The Wicked six'ah
Axle/Gears: stock 3.08's
Its A cap, Gm put there so you/we wouldnt be able to change the fuel pressure.. however, if you were to drill out that cap and remove the 4 screws you could change the Fuel Pressure. This is all Described In the One of the Ultimate TBI modifaction threads..
Old Nov 9, 2006 | 10:41 PM
MavViper's Avatar
makes sense. Now if only I can figure out why I'm getting no fuel out of the injectors, I would be in good shape
Old Nov 9, 2006 | 10:54 PM
Car: 1991 Camaro RS
are you getting any fuel? Check the fuses...
Old Nov 9, 2006 | 11:08 PM
MavViper's Avatar
fuses all check out. The fuel pump works, it pumps fuel through the lines. Filter I just changed. I get fuel flowing through the fuel lines going to the throttle body. But then no fuel comes out the injectors when cranking.
Speaking of the injectors, Chiltons says I need a prytool and a fulcrum to remove the injectors. Never heard of those before, what are they? And are there any fuses/relays for the injectors themselves? I imagine there is just don't know where to look.
Old Nov 9, 2006 | 11:12 PM
Car: 1991 Camaro RS
There is One fuse Per injector, so theres two fuses..
The wires to the injectors are connected good right? I know i had to redo mine, because one of the wires was barely hooked..
Look in the front of the Manual, it has a list of tools.. The Injectors are Pressed in, I think.. The Injectors are kinda expensive.
Last edited by HiPerf_Chevyman; Nov 9, 2006 at 11:15 PM. Reason: Automerged Doublepost
Old Nov 10, 2006 | 12:07 AM
MavViper's Avatar
both injector fuses are good. The connections are fine too,both are in there solid. Don't have a clue what to look for next really.
Old Nov 10, 2006 | 04:31 AM
1988-305-tbi's Avatar
ignition control mudule? do you have spark?
Old Nov 10, 2006 | 05:14 AM
Z28guy83's Avatar
Car: 83 Z28
Engine: 400sb
check your grounds my buddy did a tbi swap in a monte from a 4.3 to a 355 tbi and it wasnt grounded als check your oil pressure switch i know some of them if i dont read oil pressure it wont let the injector pulse
Old Nov 10, 2006 | 03:18 PM
MavViper's Avatar
Spark is fine, I have all new spark plugs and spark plug wires. As far as grounds go, I think they are ok. I know the one next to my battery is kinda flakey but I am not too sure on the other ones. I would have to find them and check.
Old Nov 12, 2006 | 04:40 PM
MavViper's Avatar
Well I've narrowed it down to the fuel injectors. That's pretty much the only thing it can be from what I can tell
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Brcharrelson
Aug 26, 2015 07:47 PM
NBrehm
Aug 25, 2015 11:49 PM
