Car "stumbling" (kinda long)
Old Oct 4, 2000 | 01:49 AM
CaptainMidway's Avatar
I'm about to throw my car away and buy a 4th Gen!! (I really don't want to do that!)
My car seems to stumble or stall when I take off from dead stop or when a step on it.
At first I thought it was just a miss, so I put the old wires on. Didn't stop it. I thought the O2 sensor might be bad, nope.
How about the fuel pressure regulator? No
The Throttle position sensor? No
The cat isn't plugged so the only other thing would be the injectors, right?
Am I missing anything else? CPU bad?
Old Oct 5, 2000 | 03:42 AM
Replaced the Injectors......still won't start.
Timing maybe? (It is advanced 6*)
Old Oct 5, 2000 | 12:06 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Bet thing to do is put it on a Scan Computer which will check out all sensors, fuel delivery, and spark. From my experience, its usually something mechanical, so here are some suggestions:
1. Closely monitor your fuel pressure AFTER any regulator in the fuel system. You may have a bad pump/filter that cant handle high demand.
2. If wires/plugs are good...check/replace the HEI module
3. Inspect your throttle assembly for any possible vacuum leaks.
4. For S's & G's...a CPU swap couldn't hurt if you can get your hands on another chip
BRoss99
Aug 10, 2025 05:08 PM
customblackbird
Aug 15, 2021 10:16 PM
maroe624
Apr 16, 2017 08:29 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
squiggy2
Aug 9, 2015 09:30 PM
