Thanks again pablo
Old Oct 12, 2000 | 08:59 PM
Max's Avatar
Max
Car: '89 Camaro Convertible
Engine: LB9 Heads/LT1 Cam Holley 670 Carb
Transmission: T5 Manual
Thanks again pablo
After reading your tech article on removing the AIR pump, I was able to eliminate all of the air injection components and it looks a lot better under the hood now. I think it will be a little easier to install headers now with less in the way.
It was especially helpful to see how you re routed the drive belt. I used the same size you mentioned in the article and every thing is set.
Also, I set my base line timing at 6 deg advance with no problems so far.
Thanks again for your help.
Black 1989 RS Convertible w/43,000 mi.
Excellent Condition
LO3 305 w/TBI
Open Element 14x3 K&N
Hypertech Thermomaster
160 Degree Thermostat
Low Temp Fan Switch
Eddlebrock Performer Muffler
No Cat
B&M Stage 2 Shift Kit
17"x9" ATP 5 Spoke Alloys
P 245/45 Goodyear Eagle
HP Ultra Plus Tires
Lakewood Rear Control Arms
Old Oct 12, 2000 | 09:21 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
hey no problem, im glad they helped you, and thanks for the sentiment
Old Oct 13, 2000 | 02:14 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
I think im sending Pablo a Christmas card, i think everybody should. Hes done so much for the tbi guys. he he he.
ENGINE SPECS:
305 TBI,Open Element,K&N 14x3,Hypertech Stage I,160 Deg. Thermostat,454 GM TBI
STEREO SPECS:
JVC Kalmeleon kdlx3,Infinity Kappa 2way 6x9's,PPI 4x6 Coaxials,PPI PC2400 AMP @ 2ohm
DEI Studio 12" 4ohm DVC,Custom Box:Exactly 1 Cubic Foot
Old Oct 13, 2000 | 06:08 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
hahah thanks snuf, I cant take full credit though after all ive learned from others just as youve learned from me, just keep passing the info along
like check this out, someone posted a link to this very informative article on the NGK webpage about spark plugs on another list im on
http://www.ngksparkplugs.com/techinfo/spark_plugs/
taught me alot about plugs im sure youll find it interesting
Get Blown ?
Nov 9, 2000 02:41 AM
rsilver
Nov 8, 2000 04:17 PM
SeanSullivan
Oct 22, 2000 06:55 PM
GhoSSt
Oct 19, 2000 01:54 PM
