Setting Idle? (TPS)
Old Oct 10, 2000 | 08:18 PM
Rock90rs's Avatar
Car: 92 RS/90' vette
Engine: Heads/cam/miniram/blah blah blah..
Transmission: T5/700!
Axle/Gears: 3.08
Setting Idle? (TPS)
This is one of the few times i miss working on a holley. How the hell do i set the idle on the car? i bumped the timing a bit more after changing the cam and it Idles at about 1,000. 700 in gear. It needs to drop.. HOW?!?!?!?!
(BTW..Im not dropping the timing as a solution. It runs great where it is. )
My RS
Old Oct 10, 2000 | 08:30 PM
Rock90rs's Avatar
Axle/Gears: 3.08
Damnit,...i meant IAC,..i read the tech article, but it seems to have been made for TPI's. I dont see any screw to adjust on my TBI.
Old Oct 11, 2000 | 01:16 AM
Rock90rs's Avatar
Axle/Gears: 3.08
bttt
Old Oct 14, 2000 | 07:10 AM
Jason 85 IrocZ's Avatar
Hey Rocky
If I remember correctly you have to pull the IAC out and the little pin with the spring wraped around it is what you will turn to the left or right to back it out or move it in more.
Are you going to the Street meet tonight?
If you are going I will be there at 7:00pm to about 8:30pm
I bring the 91 RS.
Oh I also have the super charger now so hopefully I have it on the Iroc in a week or so.
Jamieson
85 Blue Super Charged Iroc-Z28 Camaro
79 TransAm
1991 RS
1999 Oklahoma Gathering
2000 SWMG
Old Oct 14, 2000 | 08:15 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
actually thats incorrect
the tbi has an idle screw and the procedure for tpi is the same as tbi (ground aldl for 45 seconds, unplug iac, remove aldl ground, start car, set idle) the screw is right where the throttle arm rests against you cant miss it its just covered by a cap that youll have to remove with a punch or awl, takes a small torx bit, t15, but i have set it using an allan wrench before
specialized
Jun 18, 2022 09:26 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
perZ
Aug 15, 2015 01:17 PM
