open element filter
Old Oct 16, 2000 | 06:19 PM
BlackBird305's Avatar
open element filter
Im starting to do some mods on my 91 firebird and i think i'm going to go with an open element filter. I've heard that its a pretty good HP to $ ratio. I've been looking at the K&N, Edelbrok, Morrosso, Summit, and Delco. Any suggestions(and part #'s)...am i going to need a drop base filter?..and will i have to relocate the 02 sensor, and the IAT sensor inside the new element?..thanks
Old Oct 16, 2000 | 06:38 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Hey man, I used a 14x2.25 because I have a 1 inch spacer. Some people use the 14x3. The PN for the 14x2.25 is #KNN-601263
The 14x3 is KNN-601280
As for the Coil, I didn't have to move mine but I did have to drill a hole in the bottom of the open element (there is a outlined hole the have engraved for u) and I put my IAC in there. So the choice is yours, if I was you, never order a TBI spacer from Jegs. Look for a Corian spacer or anything that is ONLY .5 inches high! Anything else is to high and then your open element will hit the top of your hood. But thats a whole different mod.
Eric Natzke
91 Firebird 305 TBI (ZZ4 summer of "01")
ASCD Ram Air Hood-3" custom exaust-Flowmaster 80 Series-No Cat-Edelbrock TES Headers (coated)-March Pulleys-TBI Spacer-K&N Open ELement-TransGo Shift Kit-B&M Supercooler 28,000 GVW-Hypertech Thermomaster-160 Stat-3:42 GM Gears-Auburn Posi Unit-Edlebrock Strut Tower Brace-MSD Superconducters-Accel Cap & Rotor
-Rapidfire Plugs-265/50/R15 Tires-Emmison's all Gone
http://hometown.aol.com/J007Golden/index2.html
[This message has been edited by 91Bird305 (edited October 16, 2000).]
Old Oct 16, 2000 | 08:12 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i have the GM Performance Parts/AC Delco one and i use a 14"x3" K&N...
by the way...on that pic, it on my new engine, but i used it on my LO3 trtoo and it fit like a glove.
not sure of the part nuber but i think its theonly one they got. all you gotta do is cut the cut-out out like eric said, and you're all set.
you said something about a hp:$ ratio. i donrt really think that there is much of a hp increase with the open element. BUT it sounds awesome. i would do it again ina minute jsut based on that. at most its only like 5 hp (at most!). but itlooks cool, sounds AWESOME and cleans it up under the hood a little. i would definitely reccomend that as a good first mod.
-brian
1991 Camaro RS
Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Performer Vortec Intake, Holley 670 CFM Throttle Body, Open Air Cleaner w/14"x3" K&N, Edelbrock TES Headers, Edelbrock Victor Series Water Pump, Accell Superstock Wires, Cap, and Rotor, MSD Blaster Coil, Hypertech Fan Switch & Thermomaster Chip, AC Delco Rapidfires, 3" Cat Back, Flowmaster 40 Series Muffler
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
Brian's 1991 RS
Central NY F-Body Association
[This message has been edited by Z28 Boy (edited October 16, 2000).]
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
NiG
Sep 7, 2015 11:25 PM
luvofjah
Sep 3, 2015 07:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
