AFPR Pressure Setting
Old Oct 19, 2000 | 06:56 PM
SeanSullivan's Avatar
Pablo, or whomever...
Installed edelbrock perf intake, had to make a number of mods to get it to work on my 305. Also installed AFPR, however I had to do an errand the guy did that part of the job says he set it at 13.5 psi. Sounds kinda high to me, what do you think. The car accelerates very well to 4500 rpm, with the stock intake and press reg it would go to 5300 no problem. Now it bogs about 4500 to 4700. ideas??? thoughts?? SUGGESTIONS?
Old Oct 19, 2000 | 07:11 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
did you use the TBI performer manifold or the carb performer manifold? if you used thecarb performer manifold, which adapter did you use? and did you block off the heat crossover on either?
Old Oct 19, 2000 | 07:26 PM
I used the Carb Performer, and the holley adapter plate #17-41. The heat crossover?
Old Oct 19, 2000 | 07:43 PM
Also, disconnected battery just to be sure, again. It's not throwing any codes either. The butterflies seem to be sticking at the idle stop, just a little tho. I can hear them squeaking againist the inside of the throat.
specialized
Jun 18, 2022 09:26 AM
Andrew6.688
Dec 13, 2015 10:59 AM
TheExaminer
Aug 26, 2015 04:59 PM
355sbcTPI
Aug 19, 2015 04:38 PM
