Fuel problem?
Old Nov 21, 2006 | 02:29 PM
RSL03's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: stock
Fuel problem?
Hey guys. went out to fire up my car this morning and it just cranked, like it wasnt getting any fuel. so i poured a little bit of fuel in the TB then went to crank, it fired up but surged bad up to 2k then would drop fast to almost dieing a few times, until it eventually did die. so i went and opened up the TB a few times under the hood. Went back and it fired and ran fine. once it starts it will drive fine. little rough of an idle but other then that runs fine. any suggestions? btw what RPM are you guys idling at?
Old Nov 22, 2006 | 01:45 PM
RSL03's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: stock
And another thing, it only happens when i let the car sit over night. any help will be appreciated.
Old Nov 23, 2006 | 07:41 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Try a new fuel pump relay - sounds like your fuel pump is not priming, so overnight your injectors are starved since no fuel gets primed and pumped through the lines to the injectors. About $6.
Old Nov 25, 2006 | 01:18 AM
RSL03's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: stock
thanks dude. gonna try that this weekend.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
