what size holley injectors do i need???
Guest
Posts: n/a
i just installed the holley 670 tbi with 85lbs injectors. my car runs so rich it is causing it to flood and miss. what size injectors would you guys recommend for my car? i have stock heads, headman headers, holley pro-jection intake, and a crane compucam 2030 hydraulic roller special with lift 429/452 and duration 204/214. i have a 5 speed w/ 3.42 posi rear end.
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
350 I assume, really either way, with that cam et all 68#ers. Then play with the preasures to get the right fuel for you. Also might start thinking custom chip (this now goes with almost everything it seems to me).
I have recently learned that all the supposed 65#/hr injectors are really 68s. There is no 65 according to Turbo City, the 350 cops had 68lb/hr, and so on.
Originally posted by J&J92RS:
[B]i just installed the holley 670 tbi with 85lbs injectors. my car runs so rich it is causing it to flood and miss. what size injectors would you guys recommend for my car
Have you removed the metal tab covering the Fuel Pressure adjustment screw on the Holley TB yet? If not remove it so when you get the new injectors you can adjust the Fuel pressure accordinally. This won't help with the 85lb/hr injectors because they are too BIG.
1988 TA 300+hp 350 w/ TBI and Holley TB unit, Holley projection intake,
WC T-5, 3.42 gears w/ Auburn posi. MSD 6A, edelbrock TES headers, dynomax 3" cat and cat-back system, ACCEL coil, polyurethane bushings all around, aluminum driveshaft, Mr. Gasket open air cleaner.
1993 S-10 w/ 4.3L V6 TBI, slightly bigger cam, Mild polish job and 3 angle valve job on heads, Edlebrock TES headers, Dynomax cat back, MSD 6A, ADS chip
2000 Kawasaki KX 125
[This message has been edited by badbird88 (edited November 08, 2000).]
Guest
Posts: n/a
i have a 305, will the 65 lbs/hr injectors still work?
thanks
92 Camaro RS
305 tbi
5-speed, Hurst shifter
stock heads
open element
k&n filter
accel 8mm wires
bosch platinum plugs
headman hedders & y-pipe
hooker maxflow muffler
gutted cat
hypertech prom
posi 3.42
holley Pro-jection intake
crane 2030 cam
thanks
92 Camaro RS
305 tbi
stock heads
open element
k&n filter
accel 8mm wires
gutted cat
hypertech prom
posi 3.42
crane 2030 cam
Probably too big without new heads and a reprogrammed prom.
It is my understanding that higher pressure with smaller injectors is better, when you need more fuel, but the next injector is just too much.
This, as a apposed to larger injectors and lowering pressure.
Maybe try 55lb/hours. Part number here. I soon will have the delco book, and will be crossreferencing into gms computer for applications.(Which is how the dealership lists their parts, this will also give me flowratings for the unknown pn#s.) https://www.thirdgen.org/messgboard/...ML/000255.html
Snuf,
Any word on price/availability of that new Rochester 2" TBI assembly for me, yet??? PLEASE?????? Trying to find one has held my project(s) back sooooo long that it is really cold here in CT and it's bumming me out. Need the TBI to get my project energy sparked-up. Oh, wait til you see the bin (and here the engine combo vs HP/Torque numbers) I'm gonna post for 350's. Just had engine dyno run done. NICE. But, I NEED THE TBI for my next stage(s) of TBI development.
Please help!!!!!!!! PLEASE!!!!!!!!
thanks
thanks
You could call and ask them about the injector size then call back and tell them you have the 85lb/hr injectors which are way too big for your mild 350 b/c if you say 305 I bet they will tell you that you should have bought the 305 TB unit and give you a harder time about exchanging them. That way when you call back the second time (and talk to a different person) you can tell them you need the 85lb/hr injectors exchanged for the ?? lb/hr injectors due to the 85lb injectors being way too rich.
Let me know what they tell you on the injector sizes available.
9192camaro
16
Feb 3, 2019 12:21 AM
toronto formula
Nov 10, 2015 06:17 AM
knight72
Aug 10, 2015 09:32 PM
