FIRE IN THE BORES!!!! AHHH!!
Old Dec 1, 2000 | 06:03 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Actually it was in the butterfly valves. Ok, I have my car stored, and I went out to just start it up and keep the gas fresh in there like I usually do once every week. Anyways, I took the open element off and was reving then engine with the throttle cable to get the engine hot. All of a sudden, BOOM, flames appeard and then died out immedietly down the butterfly valves and a quick puff of smoke. Car didn't stall out or nothin, it just kept on running like nothin happened. So what was that all about? Check my sig and see if it has to do with any of my mods. Thanks.
Eric Natzke
91 Firebird 305 TBI (ZZ5 summer of "01")
ASCD Ram Air Hood-3" custom exaust-Flowmaster 80 Series-No Cat-Edelbrock TES Headers (coated)-March Pulleys-TBI Spacer-K&N Open ELement-TransGo Shift Kit-B&M Supercooler 28,000 GVW-Hypertech Thermomaster-160 Stat-3:42 GM Gears-Auburn Posi Unit-Edlebrock Strut Tower Brace-MSD Superconducters-MSD Cap & Rotor-MSD Blaster Coil-Rapidfire Plugs-265/50/R15 Tires-Emmison's all Gone
http://members.aol.com/j007golden/91firebird.html
Old Dec 1, 2000 | 07:30 PM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Axle/Gears: Moser/Strange 9" 3.73, spool
Hahaha, your car is possesed.
I have no idea what caused it, but it sounds like it misfired somehow and backfired into the intake. Carburated cars like to do that alot too.
1992 RS
327, Modded TBI, Rebuilt WC T-5 5-speed, PRO 4 15" rims, Nitto's, 3.73's, SLP 1 5/8" headers, and a few other things.
Old Dec 1, 2000 | 09:02 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Yeah I know, LoL. Somebody call an Exorcist! Maybe it has to do with it sitting there for awhile. Like maybe condensation build up somewhere or running lean maybe? I don't know, what do u guys think?
Eric Natzke
Old Dec 1, 2000 | 10:02 PM
cobrakiller1989's Avatar
hey eric,
im not sure, but this could be the problem. What is your timing set at. when i first did my swap my timing was really retarded and the engine backfired like 3 times. it was just like you explained also.
just a suggestion and a place for you to start.
good luck man
Old Dec 1, 2000 | 10:21 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
I didn't backfire. It was just like a quick spark of flames in the TB bores and then nothing, then engine ran fine. No noise, just a puff of smoke real quick.
Eric Natzke
Old Dec 2, 2000 | 03:40 AM
ONEFINE8T9's Avatar
Eric, sitting for a while and running lean wouldnt couse something like that. I wish i had the answer but i have no clue.
1989 pontiac firebird
bright red exterior(just repainted)
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
system: 2 10" MTX thunder 2000 in a Professionally done custom bandpass box.
Blaupunkt CD player
Blaupunkt 4x6 and 6x9
600 watt rockford fosgate 4.6 amp
http://members.aol.com/j007golden/Mikey89.html
Old Dec 2, 2000 | 09:05 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
leaking injector into the manifold, fumes build then you start the cold car and poof a cold valve doesnt close all the way and ignites the fumes in the manifold???
I dont know but it sounded intelligent didnt it? Im just guessing. i dont even know if thats possible.
RS Reaper
Oct 17, 2018 07:52 PM
FormulasOnly
Jul 23, 2018 08:47 AM
hartsmike
Oct 2, 2015 07:11 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
indygene
Sep 26, 2015 11:21 AM
