Resetting after open element install
Old Nov 28, 2000 | 06:00 PM
Josh 91RS's Avatar
I put on a new open element k&n this weekend and i noticed in an earlier post someone said you must disconnect your battery nd let the computer reset to take advantage of your new power...is this true...i felt more throttle response right off the bat without doing this but that may be because my old filter really needed to be replaced.
Old Nov 28, 2000 | 06:08 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
if you disconnect your neg cable, it will reset the block learn multiplier numbers or (blm).
This in essence means that your computer will start adjusting your air fuel ratio from scratch again, without taking into consideration your old a/f ratios when you had your stock aircleaner on.
so yes, you might notice a gain. slight.
IM: snflupigus | ICQ: 96787192
ENGINE SPECS:
305 TBI,Open Element,K&N 14x3,Hypertech Stage I,160 Deg. Thermostat,454 GM TBI
STEREO SPECS:
JVC Kalmeleon kdlx3,Infinity Kappa 2way 6x9's,PPI 4x6 Coaxials,PPI PC2400 AMP @ 2ohm
DEI Studio 12" 4ohm DVC,Custom Box:Exactly 1 Cubic Foot
Old Nov 28, 2000 | 06:41 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
The BLM's are continous so the car will learn new adjustments all the time. I wouldn't bother with resetting them. My past experience suggests that if you do, the car will run a bit rough for the first few minutes...then smooths out as it learns.
92 Camaro RS LO3, 5-spd, T-tops
Mechanics:
Open Air Element w/K&N Filter, Flowmaster 3" Cat-back Exhaust, Z28 Grille w/aftmkt fog lamps
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-90 Amps powering 2 12" Pro Red subs and 4 Infiniti speakers.
NEXT UP: SLP 1 3/4" Headers/Y-pipe, Centerforce Dual Friction Clutch kit
Old Nov 28, 2000 | 07:29 PM
snflupigus's Avatar
correct, it will run a little rough till it learns and adjusts a/f. True, you dont have to, eventually it will adjust to correct levels. But say you are rich, then you do something, then you are lean. starting in the middle makes more sense than having to have the computer comensate from one end of the spectrum to the other. also, disconnecting the cable takes seconds. guess you do have to reset your damn radio stations though
Old Nov 29, 2000 | 05:25 PM
DM91RS's Avatar
Car: 91 RS
Here's a tip. There is a fuse just for the computer located by the battery. Just pull it's holder out of it's waterproof cover and remove the fuse to reset the computer and you will not disconnect anything else. Hope this helps.
91 RS 305TBI T5 3:08 16" GTA'S 255 50 16 ZR'S
Old Dec 2, 2000 | 10:09 AM
BlackBird305's Avatar
when u don't disconect the neg. battery cable about how long does it take for the computer to reset?....i'm asking because i put on my open element and i picked up a little spark/octane type pinging and it seems like i'm running a little lean although i only drove for about 10 minutes after i put it on.....is this normal?...thanks
Old Dec 2, 2000 | 07:30 PM
snflupigus's Avatar
read this, its from the best damn garage on the internet.
Understanding the Block Learn Multiplier & Integrator Functions
It will explain how the computer resets and adjusts the computer all the time. There is no objective answer of how long your computer will take to reset to its new airflow and or fuelflow.
Open Element Tech Article
ENGINE SPECS:
STEREO SPECS:
Frozer!!!
Jan 19, 2024 04:55 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
wruiz
Aug 13, 2015 09:07 PM
