help pick a cam??? plz
Old Dec 8, 2000 | 12:07 AM
UnderDogRS's Avatar
ok, i need a cam for a full roller 350 w/ a .480" max lift.
roller 350,timing set & rockers
high vol oil pump
stock tpi heads but later better heads.
full exhaust, 2600-2800 rpm stall
3.42 gears, custom chip and carb intake w/ tbi adp.
i want to drive it every day. and run mid 12's(if possable) and a bit of a lope will not humt my feelings
tia,
RS
1992 Camaro RS
Mods:
14x3 Open element w/ K&N filter, MSD 6a, MSD GM blaster Coil ,MSD 8.5 SC wires, AFPR,Fuel Pressure gauge(60Psi max), 3-Row Al rad. , 180* t-stat, Hooker 1 5/8 headers, 3" Catco cat, 3" Hooker Aero Chamber cat-back, "Ultimate TBI" mods
Best Time: 15.279@89.02MPH
Underdog Racing
[This message has been edited by UnderDogRS (edited December 07, 2000).]
Old Dec 8, 2000 | 11:51 AM
FastBroker's Avatar
Comp Cams has a TBI specific roller cam. I think PN=08-500-8??? .480.488 lift with 206/212 at 050 112LS and 258/264 Adv duration. NIce..................
Old Dec 8, 2000 | 12:14 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
that cam is essentially a slightly hotter L98 cam
I think youll have a hard time going twelves with those heads unported with any cam but id look at an Lt4 hot cam or something larger
i think the lt4 hot cam with regular 1.5 rockers is around 480 lift im not certain though
Old Dec 8, 2000 | 12:17 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
btw id really look at porting those heads or possibly getting better heads
crappy heads and good cam = crappy car
crappy cam and good heads= still a good car
the power is in the cyl heads
Old Dec 10, 2000 | 07:07 PM
UnderDogRS's Avatar
i would get better heads later in the year,
but i would like to put the cam in before i install the 350. im thinking drat "pro1" heads but x-mas i kill my car funds =)
thanks again,
RS
Old Dec 10, 2000 | 10:06 PM
Basett Racing's Avatar
The Dart Pro1's are really good heads and they are drilled for perimeter and centerbolt style valve covers. They have the old style intake bolt pattern though. We recently put a set of the 200cc's on a friend's 84 vette. They really woke that bad boy up!!
Old Dec 12, 2000 | 03:02 AM
UnderDogRS's Avatar
what about crane cams cam pn#109821 sound?
cam
thanks for the help
[This message has been edited by UnderDogRS (edited December 12, 2000).]
Old Dec 12, 2000 | 07:54 AM
FastBroker's Avatar
I thought you wanted .480" lift max? That cam is .509"???
Old Dec 12, 2000 | 11:46 AM
UnderDogRS's Avatar
i need to learn more about cams, guess i'll keep reading! but anyway would it be worth the extra $$$ to get standard diameter springs that will take the "bigger" cam. i figure if im going to spend the money and do something , i should do the best job i can.
thanks for the help,
RS
Old Dec 12, 2000 | 04:22 PM
Yes! Its always a good idea to put new, better springs on when changing to a bigger. longer duration cam. Changing the springs, alone, on a high mileage engine will give you better performance. The bigger cam needs the spring pressure to acheive its power and
RPM capability.
Old Dec 13, 2000 | 08:53 AM
FastBroker's Avatar
BR is correct. New springs are some of the best $30-$100 you can spend...
junkcltr
Aug 2, 2019 11:12 PM
Street Lethal
Apr 30, 2019 12:14 PM
Below Average J
Members Camaros
23
Nov 18, 2015 10:03 PM
camaro71633
Sep 1, 2015 10:24 AM
inferno15
Aug 29, 2015 01:48 AM
