Help Please (im begging here)
Old Dec 13, 2000 | 07:10 PM
Palz's Avatar
I have a 92 Camaro with a 305 TBI. A couple weeks ago while driving it started acting up. If I tried to give it gas it acted as if a choke was on or it could not get enough gas. Never died and idled ok (minor hicups). Never died and was able to get it home by barley giving it gas. Hour later after checking the fuel sytem to see if the pump was working, which it worked fine I fired it up and it ran fine. Went ahead and replaced the fuel filter at that point to play it safe. Ran fine for a week and then today it did the same thing. Weird... Any thoughts as to what this might be?
Old Dec 13, 2000 | 08:55 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
my friends IROC had a kinda similar problem...his cat was clogged BIG TIME. the whole inside rotated like 90 degrees and blocked all air flow. maybe check that out??
-brian
1991 Camaro RS - Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Performer Vortec Intake, Holley 670 CFM Throttle Body, Open Air Cleaner w/14"x3" K&N, SLP 1 3/4" Stainless Headers, Edelbrock Victor Series Water Pump, Accell Superstock Wires, Cap, and Rotor, MSD Blaster Coil, Hypertech Fan Switch & Thermomaster Chip, AC Delco Rapidfires, 3" Cat Back, Flowmaster 40 Series Muffler
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
Brian's 1991 RS
Central NY F-Body Association
Join the Third Generation F-Body TBI Web Ring
z28boy@twcny.rr.com IM name: Z28 Boy
Old Dec 13, 2000 | 10:33 PM
Palz's Avatar
So did he have to buy another cat or what and how do you check it?? Just pop it off? Ill try checking that out.
Old Dec 15, 2000 | 08:29 PM
Eggplant Jeff's Avatar
Heh, good luck "popping it off". I had to cut mine off, which kind of made "testing" it a moot point. I had a catco replacement ready for just that eventuality though.
Nomar116
19
Feb 16, 2010 01:46 PM
HybridZ
Aftermarket Vendor Review
Jan 15, 2004 05:33 PM
MechCD
Nov 20, 2003 02:20 PM
91L98Z28
Apr 29, 2002 07:07 AM
