A/F and eletric fuel psi guage... good ones and bad ones??
Old Dec 12, 2000 | 12:40 PM
UnderDogRS's Avatar
who makes a good A/F ratio and eletronic fuel pressure guages. im going to install them and would like to know that the set i get is correct.
p.s
any pics of these in a pod setup would be a plus!
tia,
RS
1992 Camaro RS
Mods:
14x3 Open element w/ K&N filter, MSD 6a, MSD GM blaster Coil ,MSD 8.5 SC wires, AFPR,Fuel Pressure gauge(60Psi max), 3-Row Al rad. , 180* t-stat, Hooker 1 5/8 headers, 3" Catco cat, 3" Hooker Aero Chamber cat-back, "Ultimate TBI" mods
Best Time: 15.279@89.02MPH
Underdog Racing
Old Dec 12, 2000 | 09:47 PM
Andy89RS's Avatar
For A/F guage Autometer is by far the best, the others I've seen only have 3 l.e.d.s for lean, stoich, and rich. I'm also planning on going with Autometer full sweep fuel pressure guage. Here's a pic of my A/F guage in a pod mounted on the right switch pod:
"Racing is life. Everything else is just waiting." - Steve McQueen - LeMans
305 TBI, T-5. 15.4@92 mph
Member Southern California Third Gen F-Bodies
AOL IM: Andy89RS
Old Dec 13, 2000 | 06:57 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I have the Autometer electric fuel pressure gauge. Way more reliable than any mechanical using an isolater. Reads accurate with no vibration either. I'm planning for an A/F ratio gauge as well.
Mongoose-NCTGA-1990 Pontiac Formula/305 TBI-700R4 with Edelbrock Performer TBI intake,TES headers,and STB,K&N,MSD-6AL,Holley laser shot coil,Accel Extreme 9000 wires,Jet Stage 2 chip,TCI shift kit with corvette servo,Richmond 3.73 gear with Auburn 3 series posi,no cat,SLP 3" cat back,Eibach sportline springs,Energy Suspension poly throughout,Lakewood LCA and adjustable panhard bar package,SSM subframe connectors,IROC wonder bar,Tokico 5 way adjustable struts and shocks,Autometer electric fuel pressure gauge,Alpine,JL Audio,MB Quart,92 GTA taillights,92 GTA aero wing and hatch,Steve Spohn LCA relocater kit,MacEwen White face gauges,84 T/A cold air induction air cleaner.
Old Dec 13, 2000 | 05:35 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
andy, where you get the carbon fiber stuff?
Old Dec 13, 2000 | 10:08 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
p.s
tia,
RS
The OEM GM 3rd Gen O2 sensors are a switching type. Meaning the only thing they do accurately is switch form lean to rich at 14.7:1 at about .44v..
They are subject to exhuast back pressure and EGTs to throw off the readings, other then *roughly* the switching point.
NTK, Baily and Motec have nice ones for about a grand.
There is a DIY one at the GMECM site.
People have kinda gotten away with as a rough guage, but others have had it bite them when they tune to a volatge of a specific value, nothing beats reading the plugs.
I've had both mech and elec FP guages fail and with either would run an isolator.
Old Dec 13, 2000 | 10:54 PM
snflupigus's Avatar
a grand???????what??????
Old Dec 14, 2000 | 11:52 PM
Andy89RS's Avatar
snflupigus: I made that carbon fiber trim myself. I got a sheet of self adhesive carbon fiber (looking) trim at a local Hobby Shack and cut it out to match. Getting the curves just right is a whole lot more of a bitch that you might think!
AOL IM: Andy89RS
Old Dec 15, 2000 | 04:57 PM
snflupigus's Avatar
well it looks great, i have the newer style dash since ive got a 92, but im still gona try and integrate it somewhere. thanks
Old Dec 17, 2000 | 08:21 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
If you want an actual Air Fuel Ratio Meter, they cost about a grand. Yes.. The oem ones are switching types. They change outputs with EGT, and back pressure changes. If you get ahold of any good data logging with a real wide band vs a gm style you can see the oem swing about .3 (AFR) while the WB is steady. The voltage for a particular AFR can also change from pass to pass. There are a total of 2 redially available WB O2 sensors, and the NTK series as used in the one Honda is $230. Yes that is just for the sensor, You simply can't get a $30 sensor to be a precise devise. Like I mentioned if you read the DIY_EFI archives, you can find out the truth about them. Hell, the CARB, and EPA aren't even sure they are reading O2 content anyway.
If you used the same sensor on the same car as what folks like K+N do (and otheres do), then to some degree, you would have an INDICATION, of the AFR. But that's just about it. Folks are just tooo willing to beleive advertizing.
Old Dec 18, 2000 | 09:58 AM
snflupigus's Avatar
but isnt it a good enough indication to know if you are rich or lean, like a scantool?
Old Dec 18, 2000 | 11:02 PM
Andy89RS's Avatar
For a grand I better get more than an air/fuel reading...
9192camaro
16
Feb 3, 2019 12:21 AM
mustangman65_79
Apr 14, 2017 05:37 PM
justin57
Aug 20, 2015 07:05 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
Kaweh
Aug 9, 2015 02:54 PM
