What is the name of that chip burning sight?
Car: 90 Chev Suburban 4x4, 5.3L, th400
Engine: 2002 5.3 Vortec swapped in.
Transmission: Stock th400
Axle/Gears: 10blt front/ 14bltSF rear 3.73 gears.
What is the name of that chip burning sight?*nevermind-found it*
There is a sight that this guy runns and will burn custom chips for you. Anyone know what it is? i swear it was like tbiguy.com or tpiguy.com but i got nothing so far.
It was tbicips.c.om...
Car: 1992 Camaro RS (Z28 Clone) Z03
Engine: 305 TBI
Axle/Gears: Eaton POSI/ 3.73
Its tbichips.com. Ask for Bryan. I got my custom chip from him and it made a world of difference in the way my car performed, after I built my engine.
Car: 86 Iroc 383 carb, 97 T/A WS6
Car: 1988 formula
Engine: 93' LT1 Swap in progress..
Car: 1983 G20 Chevy
Transmission: 4L60
x2 Supreme Member
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
x 4At least you can learn something and later on you wont have to spend so much money back and forthing it to the programmers....just have fun and take your time. READ EVERYTHING.
Car: 91 RS
#5......................I'm lazy but I can burn a chip and not being a rocket scientist just makes it harder.The worst you can do is learn something......
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
X6. Doing it yourself is the only way to go. Heck, bump your fuel pressure by 1psi, and advance your timing 4 degrees. That is all those tuner chips do. Learn to do it yourself, you will get better results, and able to tune it for when you do real modifications.
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
all you need to know to do basic tuning is like 5 tables, VE, spark timing with the adder table, BPC, and im sure im forgetting another,, its not that hard, if you can dodge a wrench you can dodge a ball, and if you can set your timing at the dissy you can do it on a spread sheet, but you look so much cooler doing it on a laptop. for the cost of 3 custom chips you have all you need, hell buy the stuff and the guys here will get you started.
Car: 89 Camaro RS
Engine: LO3
Axle/Gears: 273 pegleg
Ok, for an old guy with his first computer controlled high performance car, and knows nothing about ALDL or baud programing, is there a site that explains chip reading and burning in detail? Something so easy even a caveman could understand it??
Dave Berry
Dave Berry
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
i think it was called, hmm.. thirdgen.org...jokin man joking,, check out the FREE TUNE sticky at the top of the forum
KO1
16
Oct 15, 2015 05:00 PM
