Should I TBI To TPI my Suburban?
Old Jan 18, 2001 | 11:14 AM
Lowlevel89Sub's Avatar
Sorry to post questions about Suburbans here but,
I may be able to get ahold of a rear ended 87-88 IROC 350 TPI 70,000 miles.I drive an 89 GMC Suburban with a 350 TBI 200,000 miles.Sometime this year i am going to have to decide what to do with my engine.(It has this phantom tick)I dont know what is involved in switching from TBI to TPI in my truck but have been reading what is involved in doing this to an F-body.
I am basicaly looking for opinions here.I put about 80-100 miles on my truck a day(90% freeway).Will my TBI "unit" fit a TPI's heads?(ports/asperation). Or should i just go ahead and switch completely to TPI?I am personally leaning towards useing my TBI on the TPI 350 block/heads.What problems (LOL) do you guys know i will run into? ie: TBI doesnt push/pull enough for the TPI 350 ect.
Thanks , Later...
89 GMC Suburban 350 TBI,700r4, 4.10's, 33"BFG
"Almost" 3/4 ton 4x4.
One From None
Old Jan 18, 2001 | 11:46 AM
cobrakiller1989's Avatar
Personally, I think if you decide to use the IROC engine (L98 i believe). I would go ahead and use the TPI. I have heard that TPI has more low end torque than TBI, and that would probably be real good for your big truck. Dont quote me on this, because some guys on here will probably try to rip me apart for saying this, but I think TPI gets better gas milage too(not sure), for you 90% highway driving. My main point being the IROC engine was made for TPI so stick with it, or have your truck engine rebuilt. That is my opinion.
GOOD LUCK
Old Jan 18, 2001 | 12:33 PM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
What type of TBI is on the burban now??
Old Jan 18, 2001 | 12:43 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Oh no, you said something was better than TBI, your gonna get ripped on man, for sure.
I agree with Tom though.
Old Jan 18, 2001 | 12:47 PM
Rock90rs's Avatar
Car: 92 RS/90' vette
Engine: Heads/cam/miniram/blah blah blah..
Transmission: T5/700!
Axle/Gears: 3.08
I agree on the TPI. Even more if you plan on wapping that L98 in stock form. It was made to run on the TPI, thats the way to keep it.
Plus, it will be kinda unique, a TPI suburban. Dont see many of those.
305 TBI
700-R4
L98 cam, 1 5/8 headers, 2 1/2 y-pipe, 4bbl edelbrock performer, holley adapter, open element K&N, afpr, flowmaster catback, MSD coil, accel wires cap & rotor, vette servos, shift kit, 2000 stall converter, TC lockup switch, all the free mods and some I left out.
Old Jan 18, 2001 | 12:59 PM
Tas's Avatar
Tas
a Suburban needs TORQUE so do this: 383, Edelbrock TBI intake, Trick Flow 23* heads, and the rest of the edelbrock TBI performer kit(cam & headers). Last 383 TBI buildup I read about had 450 TQ.
-Tas
'89 Formula WS-6
[soon to be Torch Red with black hood and headlights =) ]
305, TBI, auto, 14x3 chrome flat based open element with K&N, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Super GRK_Taz World
EFI & Intake Options
AOL IM: superGRtaz
ICQ 82881207
[This message has been edited by Tas (edited January 18, 2001).]
Old Jan 18, 2001 | 02:44 PM
thats what i was affraid of,
How much of a pain in the a$$ is it to completely switch over to TPI?(wiring).And where do i find this info?I think there is a wireing kit for this from "painless wireing co",but not 100% sure.Also i dont have the money to "Beef up" the TPI.The only thing i will do to the TPI 350 is replace the stock manifolds with headers/duals.I too think it would be nice to have a TPI in my Burb, but if its more of a pain to do this swap than to rebuild i dont want to mess with it.Like i said, this is my everyday vehicle and i dont want to run into the "oops forgot about having to do that" senerio.
The only vehicle i have seen a 350 TPI swaped into was a TOYOTA Fourunner 4x4.I didnt get to ask him what was all involved in swaping it in but it did look very nice.Thanks for the warm welcome guys.... keep the info coming.....
One From None
Old Jan 18, 2001 | 02:49 PM
Oops i almost forgot,
My truck is completely stock( other than the 3/4 ton axle swap i am in the middle of).And the Converter seems to be missing.Wonder where that went?
89 Burb 350 TBI 700r4, 4.10's 33" bfg ko's
Old Jan 18, 2001 | 03:10 PM
Rock90rs's Avatar
Axle/Gears: 3.08
I dont see how its going to be a problem considering your getting it "complete" out of a car All sensors and wireing will be there, that would kind of make it plug and play. The only problem I would forsee is the harness not being long enough to reach your firewall, there are ways to deal with that. And second you would need a high pressure fuel pump to run the TPI. Painless harnesses are a pain in the *** . But hey!, if you dont use it you can sell me all of the sensors and the ECM!
305 TBI
700-R4
[This message has been edited by Rock90rs (edited January 18, 2001).]
Old Jan 18, 2001 | 04:40 PM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Axle/Gears: Moser/Strange 9" 3.73, spool
Hehehe, I have a 89 GMC Suburban with the same miles and same engine. I've thought about doing a swap similar to this before to for when the old 350 does (if it does) die. I would go with the TPI setup, it would be cool! But seriously, I think you should use the TPI setup, if you already have it then use it, or spend more money to make the TBI just as powerful, but that would be a waste. There's tons on room under that hood so it would be an easy swap, get some headers too, that would be sweet. You'd probably get better gas milage on the freeway too.
evilstuie
Jan 9, 2020 08:29 PM
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
E Rod
Aug 28, 2015 05:17 AM
ezobens
Aug 19, 2015 10:29 PM
Sanjay
Aug 12, 2015 03:41 PM
