will stock TBI heads take .450 or .460 lift
im going to install eather a 93" (.450/.450) LT1 cam or a 95' (.450/.460) LT1 cam.
but i have 2 questions?
1: what is the max lift for stock heads
2: which would be the "better" cam.
TIA,
RS
1992 Camaro RS
Mods:
Custom chip, 14x3 Open element w/ K&N filter, MSD 6a, MSD GM blaster Coil ,MSD 8.5 SC wires, AFPR,Fuel Pressure gauge,A/F guage, 3-Row Al rad. , 180* t-stat,Proform 1.5 roller rockers, Hooker 1 5/8 headers, 3" Catco cat, 3" Hooker Aero Chamber cat-back, "Ultimate TBI" mods, Nitto 555R Drag Radials
Next
454 TB,intake,SLP Posi,3.42 gears
Al Driveshaft, Underdrive pulleys,
LT1 cam. 2400 stall Tq converter
Best Time: 15.279@89.02MPH
Underdog Racing
TIA,
RS
1992 Camaro RS
Mods:
Next
Underdog Racing
Car: '92 RS
Engine: In pieces
Transmission: Built 4L60
Heads will handle it just fine. The Springs however won't handle it. They mayu until about 3000 or so where you will have valve float. The 450/460 cam looks pretty good to me. that's about what I'm running in my '92. Check out my sig for mods. I think we will be doing alot of the sme things to our cars. And we will both be tuning our own chips so maybe we should stay in touch and help each other out. Cool?
Later,
Lars
BTW: Max lift for stock heads is about .500. That;s just becasue you run into valve/piston clearance. Get valve relieved pistons and you will be able to get higher lift.
'92 RS 305 TBI
K&N Open Element
Ultimate TBI mod's (thanks Pablo)
Cam[.442"/.465"] x 218*/224* @ .050", 10:1 Hypereutectic Pistons
Performer Manifold
Shift Kit, Corvette servo,
and 2800 Stall Trans Specialties Converter,
Gutted Cat, IAT Resistor
MSD Blaster Coil, Accel Cap and Rotor
[This message has been edited by lars92RS (edited January 18, 2001).]
Later,
Lars
'92 RS 305 TBI
K&N Open Element
Performer Manifold
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The stock springs will handle up to .480" lift.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
The stock valve springs will probably "handle" the cam as far as coil bind goes, but a set of old high-mileage springs will hamper performance to some extent on even the mildest of engines. You can open any Jeg's of Summit and get K Motion part# K-700 for for $43.00. These have 115# seat pressure and will handle around .510" lift. These are great springs for the money and they're dirt cheap. The stock locks and retainers will probably be ok, but I always replace them too. You could easily run 1.6 rockers with this combo for even better performance. The stock LT1 cam is by no means a very aggressive cam, but it will love the extra seat pressure (compared to your stock springs) and will really perform well.JMHO
82 Z28 350, Ported #882 Heads, Performer RPM cam and intake, hedman headers,650 Demon carb,
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET: 12.52@107.2
Future plans: Dart headed, Roller cammed 383 in early '01
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
New Best ET: 14.91 @92.9
http://www.bassettracing.cz28.com
evilstuie
Jan 9, 2020 08:29 PM
