INJECTOR NOT FIRING
Old Dec 21, 2006 | 05:51 PM
SPIKE's Avatar
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
INJECTOR NOT FIRING
ok, motor will run if i feed it gas. injector not pumping out fuel. measured +12vdc on red wire to injector. put test lite across injector wires, no pulse. went to pull codes and got 34 because maf was disconected. no codes after i hooked maf back up. tps volts good. any ideas where to look next ? by the way this is on a 2.5 iron duke and im a carb guy. please help !
and yes i checked all the fuses and i have power to ecm.
Old Dec 22, 2006 | 01:57 AM
MavViper's Avatar
Wow, I am having the same exact problem. I think, though not 100% certain, mine is linked to the Ignition control module and the wiring going to it. Have you tried testing it at a local auto place?
I plan on working on mine tomorrow so if I figure out what the problem was on mine I will let you know for sure.
Old Dec 22, 2006 | 09:27 AM
1320-camaro-383's Avatar
Car: 91 camaro
Engine: 383 demon 750 rpm heads 150 shot no
Transmission: bto 700r4 stage 3
Axle/Gears: currie 9" 4:10 true track
Stupid question but is your fuel pump kicking on?Make sure you are getting fuel to the throttlebody if so buy a noid light,Im not convinced your injectors are not getting signal.A noid light plugs into the injector harnass and then you will know for sure is it is getting a signal.You shoul be able to buy one or a set for 15-20 dollars.The only other thing I can think of is some cars if you are not getting oil press the computer will shut down fuel to save the motor.
Old Dec 22, 2006 | 12:47 PM
SPIKE's Avatar
Car: 86 CAMARO
mav, going to pull module rite now. ill let you know
1320, yes fuel pump circuit all checks out and yes i noid lite tested the injector wires thats how i know in not getting any pulses.. thanks
Old Dec 22, 2006 | 01:33 PM
MavViper's Avatar
1320-camaro-383, from what I've read the oil pressure sending unit only controls the fuel pump after the car has started, not before.
I had miy module tested at Autozone near me and it tested fine though I don't really trust Autozone that much. If you want you can check out the post I have in this forum called "Still No Start".
Old Dec 22, 2006 | 05:46 PM
MavViper's Avatar
ok well my car hates me I think. Now my injectors are firing and I am getting good fuel spray but it won't fire up. I had already replaced all of the spark plugs previously as well as the wires.
Spike, let me know if it was the module or not
Old Dec 22, 2006 | 11:55 PM
SPIKE's Avatar
Car: 86 CAMARO
going to yard tommorow to get ecm. i set up a pulse generator and injector fired fine car ran great. checked dizzy its good.
Old Dec 23, 2006 | 02:39 AM
MavViper's Avatar
I would advise into getting a new ecm rather than going to a junkyard. I thought the same way you did and the one I got from the junkyard was bad cause it started throwing numerous codes. I bought a brand new one and it hasn't thrown a code yet.
It's up to you though. I think the ecm from the junkyard I went to was about $45 whereas a new one is about $100 I think, maybe a little less.
Old Dec 24, 2006 | 09:55 AM
SPIKE's Avatar
Car: 86 CAMARO
mav, well the junk yard only had one ecm, and it didnt do me any good. only $15. not a big waste. also installed new icm but still no injector fire. looks like ill hav to get new ecm.
Old Dec 24, 2006 | 01:01 PM
SPIKE's Avatar
Car: 86 CAMARO
MAV, I GOT IT i replaced magnetic pickup in dizzy rite under rotor. by tracing out the wiring i figured this sends pulses to ecm to fire injectors. weird that motor woudl still run when fed gas. so that pickup must be the trigger for the injector.all that for an $8. part
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
sahlomonic
Sep 20, 2015 07:15 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
Ranbo108
Sep 9, 2015 12:20 PM
