just realized a + for all you with the tbi intake manifold
Old Jan 24, 2001 | 02:53 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
the main shute if you will is wider, so that there isnt a restriction from the tbi into the single/dual plane. but instead it is wide enough to just have free flow into the manifold. the outs on center with a 2" tb are 4 5/16. the inside width of my torquer2 is 3 3/4. so when i get my tbi to square bore adapter there will be edges that will be impeded and causing turbulance. either that or ill have a bottleneck. im not possitive what the adapter looks like.
somebody correct me if you guys with the tbi specific intakes are what i described. freer flowing. anybody got flowratings of a 2" tbi on a torquer vs a tbi specific. what am i gona loose with a bottleneck??
anyway, i think i should stopp thinking for the night
Old Jan 24, 2001 | 03:11 AM
Tas's Avatar
Tas
Pablo had to grind and angle his intake because the TBI is wider. or make a spacers that angles the bores inward. like how the TBI to 2 barrel carb intake adapter is angled from Howel. basicly funnels the TBI inward to the center.
-Tas
'89 Formula WS-6
[soon to be Torch Red with black hood and headlights =) ]
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Super GRK_Taz World
EFI & Intake Options
AOL IM: superGRtaz
ICQ 82881207
[This message has been edited by Tas (edited January 24, 2001).]
Old Jan 24, 2001 | 06:03 PM
steve8586iroc's Avatar
How about turning the tb about 45* [/] instead of [-] allowing the bores of the tb to cover the widest part of the plenum on the manifold. I know that the throttle and tv cables would require some work but if it worked well it might be worth it.
Steve
[This message has been edited by steve8586iroc (edited January 24, 2001).]
Old Jan 25, 2001 | 01:03 AM
snflupigus's Avatar
funny, i brought this same idea up to pablo and he told me to get off the drugs.
i think you would have a problem with even air fuel to the cylinders that would now be closer to the tb bores. but, couldnt hurt to have somebody try it sometime, i think it could be done with maybe a single plane insert that might help bandage the incorrect distribution problem im assuming it would cause.
Old Jan 25, 2001 | 04:42 PM
I don't think it would matter considering that you do not center the throttle bores over the center of the opening of the intake when you use a tb adapter. I really think it would work the same. The engine doesn't know if it's in the front ,back or diagonal. It will still have the same effect. It also shouldn't matter whether it's a single plane or dual plane manifold.
[This message has been edited by steve8586iroc (edited January 25, 2001).]
deracer
Apr 11, 2016 12:04 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
theurge
Aug 21, 2015 12:46 PM
Jake_92RS
Aug 11, 2015 10:39 AM
