Better computer for TBI?
Old Jan 30, 2001 | 06:38 PM
Tas's Avatar
Tas
why can't the speed density TPI computer work? there is no MAF in either case.
-Tas
'89 Formula WS-6
[soon to be Torch Red with black hood and headlights =) ]
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Super GRK_Taz World
EFI & Intake Options
AOL IM: superGRtaz
ICQ 82881207
Old Jan 30, 2001 | 06:57 PM
89RS355's Avatar
Tas, that is a really good question. I wish I knew. Maybe someone here can enlighten us.
Jerry
89 RS Lt Blue T-Tops T5
355 Crate, Compucam 2040
Pst Front Hotchkis Rear
Edle. TES 3" Flowmaster
Harwood hood, bla, bla, bla...
94 Z28, LT1 6M, Black
Most of the bolt-ons
Old Jan 30, 2001 | 07:39 PM
Andy89RS's Avatar
Look further down the board. I believe Kevins dad recently ran a TBI with a TPI computer, although I'm not sure whether it was MAF or SD. If I remember correctly they had mixed results with it. I'll see if I can find that post...
Old Jan 30, 2001 | 07:44 PM
Andy89RS's Avatar
Found it! It was speed density. Here's the post: https://www.thirdgen.org/messgboard/...ML/000505.html
Old Jan 30, 2001 | 08:03 PM
Tas's Avatar
Tas
hmm. my next project should be doing the TPI computer swap and throw 8 injectors on a Torquer 2 intake.
Old Jan 31, 2001 | 11:02 AM
FastBroker's Avatar
Or you cpould just keep your TBI computer, get the Edelbrock harness (TBI to MPFI 8 injector splice-in-harness, $35?) from Howell and use your TBI unit (without injectors) as the air control device. This way, all the idle control/air control stuff is all done. All you should have to do to get you in the ballpark is change the BPW on the PROM to match the MPFI injector size you are gonna use... WEIAND make MPFI conversion manifolds, by the way, for a pretty decent price and you can get rail/regulator kits, too. Just trying to make it easy to try/tune. I'm gonna try this later but no motivation until salt/sand is off the roads for the Winter...
92firebirdguy
Sep 1, 2016 07:53 AM
BLK87Z
Sep 18, 2015 11:29 PM
89bird2.8
Sep 18, 2015 07:46 PM
Glowsock
Sep 11, 2015 11:09 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
