What is required to make a 350 TBI work on a 305?
Hello,
I just saw a 350 TBI system for sale on Ebay and I was wondering what had to be changed to make it work on a 305. I would be using Trick Flow heads, and an Edelbrock intake and cam. Could I do it with just changing the computer and injectors?
Thanks,
Matthew C. Hall
Thanks,
Matthew C. Hall
Matthew, the 305 and 350 tbi unit are the same except for the injectors flow more fuel on the 350. You need only to change the injector pod to make yours the same as.
You would be better off doing the ultimate tbi mods that are listed in the tech section on this site, before going to larger injectors IMO.
Steve
Steve
db057
Aug 11, 2015 10:11 PM
