TBI Timing Procedure
Old Jan 3, 2007 | 05:51 AM
92 Heritage RS's Avatar
Car: 1992 Camaro RS Heritage
Engine: 305 TBI
Axle/Gears: 2.73 open 28 spline
I attempted to do a TPI conversion with no success and I switched back. Now my timing is way off and all I get are flaming backfires out of the throttle body. I need to know what the proper procedure is for setting timing and which post on my distributor is for the #1 Spark plug? Here's my setup, 1992 Camaro RS 305 TBI with automatic Trans. BTW, I'll have a nice clean TPI setup for sale soon.
Old Jan 3, 2007 | 07:23 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Follow the #1 spark plug wire to see where it connects.
Disconnect the EST, and set the dist. to around 0 degrees TDC. Maybe 2 deg BTDC. Shut the car down, reconnect the EST, and restart.
Old Jan 3, 2007 | 08:13 AM
Engine: 305 TBI
I can't even get it to start running at all! Which connector is the EST, is it the one near the A/C connections? And how do I know I'm at top dead center? I'm guessing I'll have to use a timing light right, which I don't have. I also didn't mark the dist. cap when I pulled the wires off, I did mark the wires though, and they're correct. I always seem to do a good job of screwing things up! Thanks for the help and listening to my rant.
Old Jan 3, 2007 | 01:44 PM
Car: 88 Camaro SC
Engine: SFI'd 350
You can locate #1 TDC by removing the spark plug and sticking your finger in the #1 cylinder sparkplug hole. Using the appropriate tools (NOT the balancer bolt) turn the motor over and observe when the engine is coming to TDC. If you feel pressure trying to push your finger out, your at #1 TDC. No pressure, #6 TDC. As for the dist., it doesnt really matter so long as the wires are in the right order and the rotor is pointing at the #1 cylinder plug wire with the engine at TDC.
Old Jan 4, 2007 | 10:30 PM
Engine: 305 TBI
Thanks. That was the exact advise a buddy of mine gave me, It worked well. I'm still a few ticks off on timing though as the car is pinging pretty good. I'm going to stop by Autozone tomorrow to have them check it out.
Old Jan 6, 2007 | 09:33 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
In addition to what Dimented said refer to the "LT1 cam digest" sticky above. it has detailed timing instructions.
MustangBeater20
Oct 29, 2022 09:20 PM
specialized
Jun 18, 2022 09:26 AM
evilstuie
Jan 9, 2020 08:29 PM
