HOMEMADE OPEN ELEMENT
Old Feb 19, 2001 | 02:19 AM
speedlvr's Avatar
Tonight I took the air cleaner off and cut all off the bottom but the bottom piece that the filter sits on. Works real good!
Old Feb 19, 2001 | 02:28 AM
big tex's Avatar
sounds inventive, and welcome to the board.
1992 305 TBI RS
Flowmaster cat-back exhaust, 14X2.5 open air element...and a T-5 on the way!
Old Feb 19, 2001 | 05:03 AM
JPrevost's Avatar
Car: 91 Red Sled
I smell a tech article. Just make it look nice
, Jon (91 RS too many mods to list), getting new engine in summer
Old Feb 19, 2001 | 05:29 AM
speedlvr's Avatar
Thanks for the welcome. I am glad to be part of it.
There was really nothing to it. I just used a Dremel moto tool and a high speed cutter to cut a hole in the bottom of the air cleaner big enough for the filter to sit on and chunked the excess. Put it and the filter on the throttle body and bolted the top on and that was it. Took about 30 minutes and saved money I don't have. How's that for a kickass tech article. Pretty plain jane, but simpler is better as long as it works.
Old Feb 19, 2001 | 08:40 AM
Get Blown ?'s Avatar
Another way to do it is cut out 2x2 squares on the sides. But cutting out the part not covering the filter works too. Next get yourself a 350 truck filter, it's an inch higher then the stocker. And you know that black ring on the air cleaner bust remove it, there's 4 spot welds holding it in place. That's budget speed at it's best.
1989 Camaro RS LO3 WCT5 0-60' 2.34 1/4 15.8@87mph
http://350.StreetRacing.org
The posi unit breaker.
Old Feb 19, 2001 | 02:26 PM
speedlvr's Avatar
I'll get a truck K&N today and I did the other mod a while back. Thanks for the info.
Falcon50
Aug 22, 2020 03:26 PM
Pac J
May 17, 2020 10:44 AM
FueledSoul
Sep 29, 2015 08:58 PM
drumstixer
Sep 29, 2015 03:02 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
