Help w/ NOS!!!!
Old Feb 19, 2001 | 08:53 PM
chevyboy07 91's Avatar
Help w/ NOS!!!!
Hey guys,
I'm definetly going to buy a fuel pressure shut off/safety switch for my nitrous install. What I don't know is what pressure I need to buy. They're non-adjustable and increase from increments of 5psi-80psi or so. So basically, what's the minimum pressure I should be running a 125 shot at on a 305 w/ stock TBI unit?
I'm posting this in power adders also.
Thanks,
Alex
Old Feb 19, 2001 | 09:56 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
well i dont know all that much about setting up nos but if i were you id run an FP gauge on there and just see what the FP drop is normally just doing a regular WOT run it can be like 1.5 psi in some cases
find out what that is and then get something just below that so the thing doesnt cut you off on a normal run
ps, hey dude im back around, ive got my car almost DIALED, you should bring yours by we'll mess with it
but you really need to lose that crappy manifold
Old Feb 19, 2001 | 11:21 PM
Hey Pablo,
Yeah....I knew that's what's best for me to do......but I wanted to see if I could cheat and have someone tell me.
Old Feb 20, 2001 | 12:53 AM
jeff88convertible's Avatar
I am running @ 12 p.s.i / timing @ 6*. I am also using stock chip. Its all trial and error brother. Be cautious of lean conditons and let the minnie mouse warm up before ya juice her. I replaced iac valve as well. Do you have the bottlewarmer? Makes a big difference. happy hunting
88 camaro rs convetible 92 rims / flowmaster/ hypertech chip/ 3.73 gears/tbi spacer/open elemnt/hollowed cat/shift kit corvette servo/k&n filters/holley tbi unit/NITRO FOGGER /VORTECH HEADS WITH GM INTAKE/future mods 350 with 400 crank/sub frame connectors ....................favorite quote " I WILL SMOKE YOU BECAUSE YOU HAVE 305" SAME GUY LATER SAYS "ARE YOU SURE THATS A 305 BECAUSE YOU JUST SMOKED ME" *************************Check out www.camaroheaven.com for hard to find parts location new hamshire
junior419
Apr 7, 2025 11:35 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
IROCZ1989
Sep 4, 2015 11:54 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
