Surge at idle/stall
Old Feb 23, 2001 | 07:01 PM
NBG's Avatar
NBG
Surge at idle/stall
Okay I have a 89 formula with a 305 TBI,
On occasin after the car is warm, it will start to idle irracticly, surge, and go real low, then surge, then go low and eventually stall.
The problem has been around for about 2 months. I live in michigan, and the weird thing is that on warmer days (in the winter) the problem will show up, to the point where I can't even drive the car.
I have replaced, TPS, IAC, distributor, cap, rotor, wires, plugs, 02.
I have also checked the fuel pressure. And replaced one of the injectors.
I finally put a scan tool on it, and everything seems fine. The problem is that the car will never act up when the scan tool is hooked up.
On occasin when it has one of its fits, it will recover, and the computer shoots back code 45...rich exhaust detected..
Does any one have any ideas
-Glenn
Old Feb 24, 2001 | 02:37 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
coolant temp sensor. try replacing. thats my guess. logical guess that is.
Old Feb 24, 2001 | 02:10 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
mine did pretty much the same exact thing. after pulling my friggin hair out for a week ot two straight, i figured out what the problem was. my timing was off. i had to advance it a LOT. if i remember right, it was like 12 degrees at like 2000 rpm. i dont really remember though...i could be wrong. but it helped a LOT. it still runs a little funny once in a while, but i also still have a stock chip with all my changes, so i guess that is to be expected.
-brian
1991 Camaro RS - Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Intake, Holley 670 CFM TB, Edelbrock Water Pump, March Pulleys, MSD 6AL, Blaster Coil, 8.5mm Super Conductors, Cap and Rotor, Rapidfires, Hypertech Fan Switch & Chip, SLP 1 3/4" Stainless Headers, 3" Cat Back, Flowmaster 40 Series
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
GM 10 Bolt -coming soon Auburn Pro Series Differential, Richmond 3.73s
Brian's 1991 RS Central NY F-Body Association
Join the Third Generation F-Body TBI Web Ring
z28boy@twcny.rr.com IM name: Z28 Boy
92camaro350cci
Oct 14, 2015 09:29 AM
IROCThe5.7L
Sep 17, 2015 07:48 AM
banksGTA
Sep 13, 2015 11:56 AM
bamaboy0323
Sep 3, 2015 06:07 AM
jbd1969
Aug 17, 2015 07:06 PM
