is it possible to move the fan switch to the intake??? more w/in
Old Feb 24, 2001 | 03:09 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
sorry about the duplicate post (i also posted this on the tech board) but i want some input from you TBI guys as well...
my fan switch right now is in my passenger's side head, which i think is the same place it is in all thirdgens. here is my question...i have an aftermarket intake meant for a carb so it has a lot of plugged up holes. can i switch the fan switch to one of these holes in the intake? it does have coolant behind it, so i dont see why not, so i thought i would ask you guys.
what do you think?
thanks,
-brian
1991 Camaro RS - Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Intake, Holley 670 CFM TB, Edelbrock Water Pump, March Pulleys, MSD 6AL, Blaster Coil, 8.5mm Super Conductors, Cap and Rotor, Rapidfires, Hypertech Fan Switch & Chip, SLP 1 3/4" Stainless Headers, 3" Cat Back, Flowmaster 40 Series
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
GM 10 Bolt -coming soon Auburn Pro Series Differential, Richmond 3.73s
Brian's 1991 RS Central NY F-Body Association
Join the Third Generation F-Body TBI Web Ring
z28boy@twcny.rr.com IM name: Z28 Boy
Old Feb 24, 2001 | 09:04 PM
NJ SPEEDER's Avatar
nope, that style of switch relies on teh pressure created by the expansion of teh head when it gets hot to trigger it. if you put it into the intake there is no telling what would happen. if you want to relocate or make a manual fan set up real easdy there is a trigger/thermostat set up made by flex-a-lite that works very well.
lata
tim
91 Camaro RS-LO3,Auto.
14.215@94.30 w/ 1.917 60'
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Feb 24, 2001 | 10:37 PM
Brent's Avatar
<font face="Verdana, Arial" size="2">nope, that style of switch relies on teh pressure created by the expansion of teh head when it gets hot to trigger it. </font>
I was under the impression that the fan temp switch messured water temp, not expansion of the cyl head. Any more info on this?
Z28Boy: Why do you want to move the sensor? If it is doing its job where it is, why move it?
Old Feb 24, 2001 | 10:44 PM
JPrevost's Avatar
Car: 91 Red Sled
z28 boy, I thought you installed the switch into the intake already and it was working!?!?
, Jon (91 RS too many mods to list)
Dale Earnhart, you have done so much, you will be missed.
Old Feb 25, 2001 | 11:32 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Jon...
the coolant temperature switch is in the intake...could you be confusing that with the fan switch??? i have always had the fan switch where it is suppsoed to go, in the haed, until now, when i moved it to the intake.
-brian
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
AkDrifted
Aug 17, 2015 07:45 PM
TA8487
Aug 16, 2015 12:21 PM
