Cheap heads?!?
Old Feb 23, 2001 | 11:41 PM
ahusted's Avatar
Cheap heads?!?
I'm looking for ideas on better heads for cheap!! I mean cheap as in $125 to $150 for a pair used. Is there such a thing? Are there any easy to locate cheap good factory heads to put on a tbi 350 other than the vortecs? How much does valve size make a difference? And where?(top end, bottom end ect...) What other things make up a "good" set of heads? I'd like to throw a mild cam in my 350. I know the swirl port heads I have now are junk from what I hear. So if I could replace them with cheap, used, better heads that would help complete the package, right? Thanks
Old Feb 25, 2001 | 11:00 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
hey man, i dont know exactly what to tell you about the heads. i would go with teh vortec if you had the money, just because they are AWESOME out of teh box compared to all other cast iron heads.
what do you have? what engine?
i am from syracuse...check out the club in the link in my signature...let me know if you might be interested.
-brian
1991 Camaro RS - Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Intake, Holley 670 CFM TB, Edelbrock Water Pump, March Pulleys, MSD 6AL, Blaster Coil, 8.5mm Super Conductors, Cap and Rotor, Rapidfires, Hypertech Fan Switch & Chip, SLP 1 3/4" Stainless Headers, 3" Cat Back, Flowmaster 40 Series
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
GM 10 Bolt -coming soon Auburn Pro Series Differential, Richmond 3.73s
Brian's 1991 RS Central NY F-Body Association
Join the Third Generation F-Body TBI Web Ring
z28boy@twcny.rr.com IM name: Z28 Boy
italiano67
Dec 11, 2016 09:21 AM
evilstuie
Apr 14, 2016 08:52 PM
dutch930
Sep 11, 2015 06:58 AM
1LE91
Aug 31, 2015 08:13 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
