Is the EdleBrock TBI performer manifold worth the money. Is there a noticable difference in the power with no other mods. I am considering putting on a 350 TBI Mastercraft and was wondering if anyone has had any good experiances.
Thanks gdkng
Thanks gdkng
First you say no other mods then you say 350 TBI in the next sentance. If it's between the edelbrock and the stock 305 intake on a 350 then the edelbrock is worth it, just don't expect any huge gains if you use the stock 305 exhaust manifolds.
, Jon (91 RS too many mods to list)
sorry, I should have specified. The truck TBI's are all 350's and so are all of the marine stuff. I was just curious of the performance gains of the edelrock TBI performer on a 350. It slipped my mind that most TBI thirdgens are 305's.
gdkng
gdkng
WELL I PUT THE PERFORMAER TBI INTAKE ON MY 305 AND I THINK ITS WORTH IT. aLTHOUGH YOU WILL GET MORE POWER OUT OF IT IF YOU GET A AFTERMARKET CAM TOO. YOU PROB GET ABOUT 10 hp GAIN WITH JUST THE INTAKE.
91 camaro RS
- 305 TBI
Mods: Performer tbi intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo, accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edolbrock springs, KYB struts and shocks
Soon to come . Posi 323 rear end , SLP boxed LCA's and panhard bar, ascd ram air hood, Z28 spoiler, white guage faces.
91 camaro RS
- 305 TBI
the performer tbi is a very good manifold. it can carry you a long way, i think it is capable of 12's.
lata
tim
91 Camaro RS-LO3,Auto.
14.215@94.30 w/ 1.917 60'
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
lata
tim
NJ Speeder, you believe the manifold is good for 12's and the bores are not even 2"? So you mean that you think it's possible to get the edelbrock performer tbi and the stock tb unit into 12's? That would be something I'd definitely like to hear more about.
Do not use that manifold for high performance high-rpm applications... Use an RPM or even a Performer carb manifold with an adapter plate. IMO
soulbounder,
we will see if my mathematical theories hold any water hopefully by mid season. i am figuring that a correctly prepped but still stock bore tb can flow enough air to support 275-300hp at the rear wheels and make peak power below 5400rpm.
i hafta fix a bunch of other stuff on the car before we find out though.
lata
tim
lata
tim
Tim, I'm right behind you in the "small TBI" is enough theory.
What combo(s) are you going to run to get your hp??? Curious to see whatcha gonna try. That's a lot of RWHp you're shooting for. Now THAT would surely be impressive.
I am soon (end of march engine removal) to try Vortec heads (slightly cleaned up/readied for the lift OR the SDPC fancy ones) with the HOT CAM kit, the 1.6 rockers and a RPM AirGap manifold. I'm only running about 9:1 CR, though, and think that cam may need/want more. I also need 80 or 90pph injectors, too, to support the hp.
Maybe we can get together here and help each other out with the combo/PROM tuning, etc... Gonna be fun!!!!!!!!!!!
my combo is pretty simple. i run the performer tbi manifold, edelbrock performer centerbolt heads, comp cams 1.6 rockers, and most of the ultimate tbi stuff.
my plans for the motor are a 97 LT1 cam and soem crane full roller rockers along with a custom chip to keep it running right. the bulk of the work i do on cars is suspension related, so that is where i plan to get most of the et from. i figure i need about 275-285 RWHP to get the approx. 105mph i think i need for a serious shot at a 12.
i hafta make sure the 101K+ motor stays together long enough to try though
if not i'll just rebuild it with 10.5 to 1 compression and make this all really easy
lata
tim
lata
tim
Just out of curiousity Tim, have your heads been shaved. If your Edelbrocks are still 60 cc and you used the composite gasket recommended for the heads, your compression should actually be around 9:1 or a little less. If this is the case, then your car mathematically would be maybe a tenth/tenth & half faster with 9.5:1 With that being said, you would have knocking hard on 13's on your last run at the track, just a thought???
82 Z28 350, Ported #882 Heads, Performer RPM cam and intake, hedman headers,650 Demon carb,
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET: 12.52@107.2
Future plans: Dart headed, Roller cammed 383 in early '01
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
New Best ET: 14.91 @92.9
Bassett Racing
Mid Atlantic F Body -82 Z28 Page
R.I.P. Dale Earnhardt #3
Bassett Racing
there are 305 TBI trucks too....
-Tas
'89 Formula WS-6
[soon to be Torch Red with black hood and headlights =) ]
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Super GRK_Taz World
EFI & Intake Options
AOL IM: superGRtaz | ICQ 82881207
-Tas
'89 Formula WS-6
Super GRK_Taz World
