305 torquer heads vs. vortecs...
Old Mar 10, 2001 | 09:56 AM
nichoulas83Z454's Avatar
just wonderin which performs better? the torquer heads have 58cc chambers but they are about $750 in jegs...
the vortecs are cheaper but they have to be milled to have the smaller chambers...
so which is worth it money and performance wise...
my income tax check is gonna be $850 this year and i got some $750 saved up so im looking to do some mods...
im installing the headers today...
im wanting to approach the 300hp mark by adding a cam, heads, hooker cat back, catco cat, pulleys, the holley projection intake, spacer, holley tbi, msd, and open element...
ive already got headers and k&n and a flowmaster...
Old Mar 10, 2001 | 10:59 AM
NJ SPEEDER's Avatar
i would say the votecs are the better head overall. how many cc is the standard chamber on them though? how much milling would it take?
lata
tim
91 Camaro RS-LO3,Auto.
14.215@94.30 w/ 1.917 60'
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Mar 11, 2001 | 02:49 AM
JPrevost's Avatar
Car: 91 Red Sled
Vortec heads stock are 64cc (stock L31 heads). The intake runners are 170cc and valve d. is I:1.94" E:1.50".
The vette heads have 58cc and 163cc intake runners and same valve size, advantage is the aluminum saves weight. Disadvantage is aluminum needs more compression to make the same hp as iron heads. I've read that if you get the heads milled then the intake ports aren't going to line up and so that should also be taken care of. Hope this helps.
All in all I think the vortec heads are the best bang for the buck but maybe not in your case since the need for machine work.
, Jon (91 RS too many mods to list)
Old Mar 11, 2001 | 07:45 AM
steve8586iroc's Avatar
I would use either the vette heads or the 305 torquer. With just a mild cam these heads will flow more than adequate. Plus there a lot less work.
Steve
Old Mar 11, 2001 | 09:56 AM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
Hot Rod magazine made 325 hp on a 305 with milled L31's, Edelbrock Victor Jr. Intake, Holley 750 double pumper, and Comp Cams XE262H-10 Xtreme energy cam. L31 Heads are great, their combustion chambers are really close those on an LT1 and They flow great too. They put WP torquer 305's on the same engine and made 300 hp.
Old Mar 11, 2001 | 06:07 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
.045' needs to be milled off the vortecs to keep compression on a 305
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 224/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, 3000 stallconverter. Edelbrock TES, 3inch cat, flowmaster with single 2.5 inch exit.
Best time yet to come
12's?? :crossthumbs:
This is a Pic of my car in race trim www.tbns.net/billyjay/camero.jpg
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
