What else is needed for this???
Old Mar 19, 2001 | 05:42 PM
MurphsIroc's Avatar
Alright, I was thinking of buying this setup from this guy. Will this just go on with nothing else needed to be done?? Or would I need to buy other stuff as well?
EDLEBROCK 1000 CFM (58MM) THROTTLE BODY with BUILT IN AIR FOIL-IAC MOTOR AND TPS SENSOR
TPIS LARGE TUBE RUNNERS
EDLEBROCK BASE-(COMPLETELY PORTED-35 CFM OVER OUT OF BOX FLOW)(COMPLETE RUNNER LENGTH IS PORTED!!!!)(PORT MATCHED TO RUNNERS)
TPIS FUEL INJECTORS (24LBS.) with FUEL RAILS
PLENUM IS COMPLETELY PORTED BEHIND THROTTLE BODY AND MATCHED TO RUNNERS & COMES WITH AIR TEMP SENSOR UNDERNEATH AND MAP SENSOR AND COOLANT SENSOR IN THE INTAKE BASE
DISTRIBUTOR (assembled)
ADJUSTABLE FUEL PRESSURE REGULATOR
Old Mar 19, 2001 | 05:47 PM
cobrakiller1989's Avatar
HOw much r u paying for all of that? Right off hand, I can tell you that you will need another fuel pump, wiring harness, and ecm for all of that stuff to go right on. If you do decide to put all of that on It will be a great improvement. Are you running a 305 or 350. Alot of it also seems like over kill. especially that 58mm TB. Let me know if you need help if you do decide to swap, i will be donig one this saturday.
good luck
Old Mar 19, 2001 | 05:57 PM
MurphsIroc's Avatar
Hey man, I will be running this setup on a 305. Do you tink with all this I will hit 13.9?? Just want to know how much power that car will then have. And how much does all that stuff you said equal up to, that I need to buy to put this setup on. thanks alot
Old Mar 19, 2001 | 06:08 PM
I think you might have some trouble hitting that time on a L03. It's just too restrictive. However, with that stuff you can mod your engine(heads, cam, and exhaust) and you will run some excellent times. Im not sure how much power you will make by just bolting all of that on, but you will have a significant increase in torque with that setup.
Old Mar 19, 2001 | 06:11 PM
Oh I forgot your prices.
In tank fuel pump-$150-200
wiring harness-$150-300 depending on what kind you get
ECM and new EPROM-$100-200
these prices are just off of the top of my head. If you go to ebay there is alot of good prices on good parts there and you might be able to get them cheaper
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
