What's this called??
Old Jan 25, 2007 | 02:16 PM
MavViper's Avatar
You know on the air filter housing there is a ducting or tubing that extends from the underside of the extended portion of the housing to some sort of exhaust outlet right above the driver side header. Anyone know what I am talking about?
Mine is seemingly missing and I can't find a replacement for the life of me. I even tried going to some places like Home Depot and they had the stuff I was looking for but was too big and didn't come in small portions.
Old Jan 25, 2007 | 02:45 PM
Yes.
It's called various things; heat stove pipe seems to be the most common.
It's hanging in little yellow and green boxes at VatoZone and other places that carry the Help! product line, near the air filters.
Old Jan 26, 2007 | 02:28 PM
vwdave's Avatar
It also might be called a "Heat Exchanger" Its to help get warm air into the engine during warmup by delivering hot air off the manifold.
Old Jan 26, 2007 | 02:39 PM
markymarco's Avatar
Car: 89 Camaro Convert,89 Camaro hardtop
Engine: 305 and a 357
Transmission: 700R4,T5
Axle/Gears: 4.10's and 3.43's
"heat riser"
Old Jan 28, 2007 | 08:13 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Thermac ?
Old Jan 28, 2007 | 08:21 PM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
thermac is the lil vacuum driven choker on the inlet tube of the stock intake peice. stovep pipe is the common slang for that little peice.
screw the stove pipe less you live in alaska. save your bucks get an open element aircleaner. less our cars are now old enough to have value as numbers matching and showroom stock,, its possible, value has doubled since i owned my anniversary.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
bschmale66853
Sep 30, 2015 08:11 PM
