programming vs. modifacation
Old Mar 23, 2001 | 11:37 AM
sy2449's Avatar
after i installed a k&n, and a edelbrock TES, i noticed if i was getting on it, when i pulled to a stop, i would get a rough idle, but if im just cruzing at light throttle, and pull to a stop, my idle is silky smooth. i feel like my PROM program doesnt quite match my combination. since my engine is running more efficiently at higher rpm, i think the ECM is trying to addjust, but has no real way to adjust the upper rpm with out adjusting the lower as well. and im wondering how you guys handle this, since your mods are even more extreme than mine. do you just put up with it, or do you somehow change the programming?
Old Mar 28, 2001 | 12:22 PM
Kyle F's Avatar
That sounds kinda funky. I would have no Idea what would cause that, but you computer should adjust imidiatly to an idle condition the same way it adjust to full throttle condition from part thrttle or idle.
What I do know is that getting the equipment to program and learning how to do it will pay off big time in the future when you do more mods or custom program for the ones you have now.
good luck in finding what is the deal with you car. Maybe it has something todo woth the extra heat that the engine makes under hard acceleration? Just a thought, doubt that has anything to do with it though.
FOR SALE!!!!!!!!!!!!!!!
86 Trans Am 355 TPI Rebuilt 700R4 with Corvette servo, modified valve body, and a B&M Torque Converter (2000 rpm stall w/ lock up), 87 350 block bored .30 with new crank. Reworked 305 heads with 3-angle valve job. Added in the rebuild was an SLP TPI cam, BBK 58mm Throttle Body,MSD 6A, Hypertech Power Coil,MSD Wires, 1.5 Crane roller tipped rocker arms, SLP Intake Runners and Port matching in upper intake including fully ported plenum, TPIS adjustable fuel pressure regulator @ 46psi, Hooker shorty style headers w/ Thermotech heat wrapping, Custom 3” exhaust with Flowmaster muffler and chrome quad tips, Hypertech Thermomaster Computer chip, K&N open element cone filter on modified MAF per TPIS specs, removal of A/C hardware and added a 1LE firewall cover installed. Also there has been a PST front suspension kit with Hotchkis strut tower brace added.
Stereo has 2 Clairion Pro Audio dash plates, 2 Sony 6X9s, 2 Kicker 12's in a custom Carpeted box with a custom amp rack Holding 3 MTX 280 Amps, and a MTX electronic Crossover all wired with EFX cable.
Asking $4200 with all extra Parts that are needed to fix most apearance flaws. ie Complete hatch and wing from a 91 GTA
http://geocities.com/feltsb/kyle.html
Kills:
95 Talon TSI, 96 Probe GT, 91 T/A L98, 89 RS, 86 Mustang GT, 88 Mustang LX 5.0, 92 Thunderbird V8. couple or ricers that I think were Civics or Preludes not sure what year, 95 Celica GT-S, 94 Chevy 1/2 ton 350, one of those NASCAR F150's
The Third Gen Will Never be Forgotten
Old Mar 28, 2001 | 09:45 PM
NJ SPEEDER's Avatar
everytime i do any mods the first thing i do is go back and play with the timing. it is the first thing that gets messed up with our ecm's for some reason.
lata
tim
91 Camaro RS-LO3,Auto.
14.215@94.30 w/ 1.917 60'
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Mar 29, 2001 | 01:43 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
kyle. you have 305 heads on a 350? whats your compression?
Old Mar 29, 2001 | 02:32 PM
stormr2000's Avatar
Iknow what ya mean with the rough idle after running hard, my bird did that after I put my 8.8's, and splitfires in it. Ijust put up with it because it didnt affect driveability or power, however since I put in my chip I havent had the problem, so it might have something to do with the programming somewere
'91 firebird-
305 TBI
Thermomaster chip
open element filter
open exhaust w/Terminator resonated tips
"If its in my way, it gets run over!"
djmarch
May 8, 2016 11:32 AM
ULTM8Z
Oct 2, 2015 01:25 PM
3.8TransAM
Sep 17, 2015 02:16 PM
f-bodyz28
Sep 2, 2015 05:03 PM
bdads
Aug 24, 2015 06:01 PM
