Any thoughts? stuttering stumbling?
Old Feb 3, 2007 | 08:36 AM
phoenix64's Avatar
92 rs 305 5-speed, tach reads high so I don't know the exact RPM, but it feels like if you get it below 2000 RPM and high load it stutters and surges really bad. If you just barely use the throttle it run ok.
If you rev it up, it runs out just fine, very very weak(at WOT I get passed by cars accelerating normaly), but its at least smooth.
I tried timing it, but I can't find the lead you need to disconect. Its at like 4-6* advanced at idle.
Does this sound like fuel pump of timing?
Old Feb 3, 2007 | 10:12 AM
phoenix64's Avatar
forgot to add it runs great when it cold, take a min or 2 to start doing this.
Old Feb 3, 2007 | 01:17 PM
phoenix64's Avatar
Easiest fix ever. Nearly died when I found the advance wire. Timing mark was a good inch off the tab negative direction. much less slow and much smoother.
Old Feb 3, 2007 | 08:54 PM
golden's Avatar
Car: '89 Firebird
Engine: 305 TBI (LO3)
Axle/Gears: 10 bolts 2.73
Great ! I was starting to think about the TPS ...
Old Feb 4, 2007 | 12:24 AM
phoenix64's Avatar
Wow power is really much better. Nothing like going from unable to get out of its own way, to doing one wheel rolling burnouts, with one turn of a wrench.
db057
Jan 10, 2020 08:55 PM
Logan Bryant
Sep 23, 2015 06:51 AM
RedLeader289
Sep 23, 2015 06:50 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
IROCZ1989
Sep 4, 2015 11:54 AM
