Difference between stock fuel pressure regulators on our cars
Old Apr 10, 2001 | 11:43 AM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
I have just taken off the fuel pressure regulator and injector pod off of my 92 RS and noticed that the stock setting is set way higher then in my 88 SC. The indicator on the fuel pressure regulator on the 92RS was half way (right in the middle) of the little opening that you look at to set the fuel pressure. On my 88, the indicator was only a 1/4 way up from the bottom. So for those of you who have noticed that 92 RS's are generally faster then older models, it could be that they were tuned better from factory. I have also noticed that the sway bar up front is way thicker on the RS.
Pat Hirsz
www.iit.edu/~hirspat/MyPage2.htm
88 305TBI
Mods:Hooker Aerochamber 3" exhaust, gutted kitty, March pullies, no smog, 180 thermo,
14x4 K&N, 3.42 gears(open), Ultimate TBI Mods,AFPR,MSD(ignition,coil&wires),Edelbrock TBI Manifold, 195ltr/hr fuel pump,
Eibach springs with KYB's all around,
Harwood cowl hood, Z-28 wing, fresh paint(black)
120,000 miles, 5spd, T-tops,slp headers on its way
92 RS, 305TBI, auto, 3.08 gears, 180 thermo, glasspack (no muffler)
Old Apr 10, 2001 | 02:33 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
i think the fuel regs are nearly random.
sway bar size? maybe a late design addition.
Old Apr 10, 2001 | 09:40 PM
NotDadsW41's Avatar
I've found different spings in two different TBI units that I've had apart recently. The longer one from a 350 truck TBI and the shorter one from a 350 9c1 Caprice TBI.
MustangBeater20
Oct 29, 2022 09:20 PM
specialized
Jun 18, 2022 09:26 AM
9192camaro
16
Feb 3, 2019 12:21 AM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
