horse power ratings of GM crate motors
I was looking into buying a 350 gm motor soon and was wondering are their horsepower ratings gross or net? I was thinking about either the 270hp 350 tbi motor or the 265hp 350.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
GM has a 375hp LS1 crate motor. If you have the green go for that. I can't remebr how much it was but it is in the range of 4k to 6k
1990 RS 305 TBI T-5
.5" turbocity spacer
Summit 14X3 OpenElement W/k&N
Custom Exhaust
MSD - Wires, Cap, Rotor, Coil
Bosch Platinum +4 plugs
Metallic Red w/26,000 miles
1990 RS 305 TBI T-5
Custom Exhaust
Thats a little out of my price range. I was looking around 2 grand. GM has a couple of motors around that price range I was looking for something in the 250hp to 300hp range that would be compatible with my stock electronics. The only real mods so far are the ultimate tbi mods and 350 injectors. So does anyone know if the motors hp ratings are gross or net?
Car: '90 RS
Engine: 377 LSX
go to www.sdpc2000.com
he sells all kinds of motors to fit your needs
1990 RS 305 TBI T-5
Custom Exhaust
1990 RS 305 TBI T-5
Custom Exhaust
Car: 91 Red Sled
Jim Pace sells the 330ho for $100 less than all other supliers and it only cost me $140 to have the engine shipped from Ohio to NJ.
, Jon (350 TBI! getting 23mpg highway)
91 Red RS w/grey int, sq stereo (Alpine v12, kicker solo, MB quart premium etc)AIM: JPrevost
- Holley 670 TB unit w/ 1/2" spacer/adapter
- Edelbrock RPM vortec intake
- 350ho 330hp vortec crate motor
- 8" harm. balancer
- Stewart stage 2 water pump w/160 thermo
- SLP tri-y headers to full 3"
- Rebuilt trans w/ SLP shift kit
- Centerline 16x8's all around
- 36/24 mm sway bars
- Full poly bushings, even motor mounts
- SLP LCA and panhard
- Alston SFCs
- Edelbrock 3 point STB
- Global west steering brace aka wonderbar
- Eibach pro kit springs
- Bilstien high perf. struts and shocks
- All this and I still have AC
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
I have been thinking about using the edelbrock 310hp or 320hp crate engines as a replacement. That way I wouldn't have to deal with the vortec egr thing and have aluminum heads. Anybody tried one. It would be nice if I could order it with the TBI manifold on it. Then I wouldn't have to worry about hood clearance either.
91 Camaro RS 5.0L Black Convertible 700R4. Owned 3 months bought from 1 owner girl. Working on that stock part.
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
I keep hearing how edelbrock cams suck *** . If you were to go with the 250HP replacement 350 it would be wise to put a bigger cam in it and add headers while youre doing the swap. The HP ratings vary so widely from application to application that its impossible for GM to rate an engine with any degree of accuracy like that. Id say with a cam,intake, headers and **** like that you could easily clear 300ponies
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 224/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, 3000 stallconverter. Edelbrock TES, 3inch cat, flowmaster with single 2.5 inch exit.
Best time yet to come
12's?? :crossthumbs:
This is a Pic of my car in race trim www.tbns.net/billyjay/camero.jpg
Yes I know how to spell camaro- so dont ask. I didnt make the link
Belive me, for the extra 75 horses you'd be putting out, solving the egr vortec problem is simple. Jim Pace, aside from selling the 350 HO cheap, also sells intake manifolds, and one of them is vortec/egr equipped. Problem solved, have a nice day.
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
