fuel pressure
Car: 1999 Tahoe LT 4x4
Engine: 5.7 Vortech 350
Transmission: 4L80E
fuel pressure
How much fuel pressure do i need to be running with my mods. How can I install a gauge to tell me what my fuel pressure is?
Transmission: 4L80E
sorry, here are my mods.
Thankyou,
Twells
1992 R.S. 25th Anniversary
* Borla
* Open Element
* Hypertech Chip
* Smog pump delete
Thats all for now!!
Thankyou,
Twells
* Borla
* Open Element
* Hypertech Chip
* Smog pump delete
Thats all for now!!
Car: 91 Red Sled
If that's it don't mess with the FP. You could adjust it a little but you probably won't feel any difference. From what I've learned, TBI fuel pressure is set and forget, TPI responds much differently to fuel pressure. When you make 50hp more than stock it might be a good idea to change the injectors to #55. Then if you go more you should look into chip programming to change the fuel curve etc.
, Jon (350 TBI! getting 23mpg highway)
91 Red RS w/grey int, sq stereo (Alpine v12, kicker solo, MB quart premium etc)AIM: JPrevost
- Holley 670 TB unit w/ 1/2" spacer/adapter
- Edelbrock RPM vortec intake
- 350ho 330hp vortec crate motor
- 8" harm. balancer
- Stewart stage 2 water pump w/160 thermo
- SLP tri-y headers to full 3"
- Rebuilt trans w/ SLP shift kit
- Centerline 16x8's all around
- 36/24 mm sway bars
- Full poly bushings, even motor mounts
- SLP LCA and panhard
- Alston SFCs
- Edelbrock 3 point STB
- Global west steering brace aka wonderbar
- Eibach pro kit springs
- Bilstien high perf. struts and shocks
- All this and I still have AC
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
