Intake Install question
Old Apr 18, 2001 | 11:55 AM
Boham92RS's Avatar
I am installing a new intake soon on my 92 RS and have a question regarding the gasket install... I am planning on using black RTV for the front and rear seals. I have seen posts that say to run the RTV up the sides of the heads a little bit as well. Is this over or under the intake gaskets? What RTV should I use around the water jackets? Also, when removing / tightening the bolts, should I follow a carb intake pattern?
Old Apr 19, 2001 | 02:20 PM
Boham92RS's Avatar
ttt
Old Apr 19, 2001 | 02:41 PM
JPrevost's Avatar
Car: 91 Red Sled
I don't know what RTV is but I'm sure I could find out. What I do is just use thick high temp blue silicon sealant. Make it really thick and it should be fine. Torque it down just like a carb intake if you've got normal bolt pattern. If it's vortec heads it's a little different, they don't require as much torque and the pattern is a little different (duh..only 4 bolts a side).
, Jon (350 TBI! getting 23mpg highway)
91 Red RS w/grey int, sq stereo (Alpine v12, kicker solo, MB quart premium etc)AIM: JPrevost
  • Holley 670 TB unit w/ 1/2" spacer/adapter
  • Edelbrock RPM vortec intake
  • 350ho 330hp vortec crate motor
  • 8" harm. balancer
  • Stewart stage 2 water pump w/160 thermo
  • SLP tri-y headers to full 3"
  • Rebuilt trans w/ SLP shift kit
  • Centerline 16x8's all around
  • 36/24 mm sway bars
  • Full poly bushings, even motor mounts
  • SLP LCA and panhard
  • Alston SFCs
  • Edelbrock 3 point STB
  • Global west steering brace aka wonderbar
  • Eibach pro kit springs
  • Bilstien high perf. struts and shocks
  • All this and I still have AC
My websiteAny questions?
Old Apr 19, 2001 | 03:28 PM
Dan W's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Boham92RS:
[B]I am installing a new intake soon on my 92 RS and have a question regarding the gasket install... I am planning on using black RTV for the front and rear seals. I have seen posts that say to run the RTV up the sides of the heads a little bit as well. Is this over or under the intake gaskets? </font>
I put a bead down across each end and maybe 1/4" up the head. The gasket then goes in place and another small dab covers the junction of the other side of the gasket and the RTV.
<font face="Verdana, Arial" size="2">What RTV should I use around the water jackets?</font>
If your talking about between the intake and heads, most gaskets don't require sealant here. Check the directions on your gaskets. On other gaskets like the water neck and water pump, I smear a thin layer or blue RTV.
[This message has been edited by Dan W (edited April 19, 2001).]
Old Apr 19, 2001 | 03:32 PM
Tas's Avatar
Tas
So far I've been apart of 3 perfect intake swaps. Run a THICK bead front and back, little ways up the heads too. Put a little bit around the water jackets too, not too much because the gaskets will smear what you put.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
EFI & Intake Options
AOL IM: superGRtaz
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
