Cost Effective Solution to L03 Rebuild or Other
Old Feb 10, 2007 | 07:26 PM
Pdiminico's Avatar
Car: 88 IROC
Engine: 5.O TBI
I have an 88 L03 which has been running like crap after replacing valve seals and oil coming out of tail pipe. Car had fail inspection due to smoke. Everywhere I look it would cost me $1500 to $2200 to rebuild it.Thats more than the car is worth.
What other option could bring the cost down around $600?
Old Feb 10, 2007 | 08:05 PM
beatercoprice's Avatar
Car: 92 & 93 caprice 9c1's
Engine: L05's
Transmission: 4L60's
Axle/Gears: 3.42's one G80, one open
Find something with a crumby or wrecked body, burnt up trans, etc and a 350 in it, pull the 350 install in your car.
Or rebuild yourself. I once did a mild performance rebuild for about 1000. Either way, if your going for power go with a 350.
Or check your valve seals again, you may have messed one up or misinstalled it since the problem is after you installed them...
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Magman
Aug 2, 2016 08:32 PM
billybob6110
Sep 23, 2015 01:30 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
