Looking for Info on Cross-Fire...
Old Apr 15, 2001 | 09:16 PM
HOT/A377's Avatar
Hi, I'm looking for info and photos of the Cross-Fire Fuel Injection. How was the manifold as far as flow is concerned?
thanks
Old Apr 15, 2001 | 11:29 PM
Russ-So Cal's Avatar
I understand that it flows very well. The biggest weakness was the computer that came with it. Turbo City in Annaheim Ca has had good success using the ecm from the 90-92 speed density tpi with cross fire to make a good reliable system. If you can adapt two two barrel tbi units to the cross fire, you might get even more power. You would need a custom chip to make it work.
Old Apr 16, 2001 | 03:04 AM
Tas's Avatar
Tas
????? the manifold was crap. 1/4 of the intake port was blocked.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
EFI & Intake Options
AOL IM: superGRtaz
Old Apr 16, 2001 | 03:43 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
its not bad.. the ports on the manifold are small but i think thats decieving.. size of the port doesnt directly relate to flow. There are a bunch of CFI cars running well anyways
Old Apr 16, 2001 | 10:29 AM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
See Sig and go here for A LOT more info:
http://www.enteract.com/~mikew/cgi-bin/Ultimate.cgi
Old Apr 16, 2001 | 10:30 AM
Engine: LT1, L400
whoops
Old Apr 16, 2001 | 10:31 AM
Engine: LT1, L400
whoops
'83 Trans Am: 400 CID oil burning junkyard long block, 224/234 crane cam, Summit aluminum roller rockers, hand ported intake, home bored 2.09" (53mm) throttle bodies, MSD 454 injectors(75 lb/hr), Holley 255LPH fuel pump, custum modded FPR, Edelbrock TES headers, SLP 3" stainless steel cat back, stock ECM & chip. Borg/Warner T-5 World Class, 12" Corvette rotors and clipers, GTA 16" wheels, South Side Machine subframe connectors, 1LE sway bars, 3.45 ring and pinion, Alpine sound.
Best E.T. 13.532
Best MPH 102.24
Old Apr 17, 2001 | 09:30 PM
jase's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Russ-So Cal:
I understand that it flows very well. The biggest weakness was the computer that came with it. Turbo City in Annaheim Ca has had good success using the ecm from the 90-92 speed density tpi with cross fire to make a good reliable system. If you can adapt two two barrel tbi units to the cross fire, you might get even more power. You would need a custom chip to make it work.</font>
CrossFire has the pot.to run ext. well as long as you got a good computer.
Old Apr 20, 2001 | 03:15 PM
thegeezer's Avatar
I've got some pictures of a crossfire from an 83 Trans Am sitting on one of my servers. It's just some giant raw pictures, no descriptions or info at the moment. Check it out:
http://firewall.geezernet.nu/crossfire
-Kevin
1982 Pontiac Trans Am 305 LG4 4sp T-10 hardtop WS7 stock
http://www.geezernet.nu/transam
1982 Pontiac Trans Am 305 LU5 TH-200 t-top, loaded
http://www.geezernet.nu/transam/blackt
Old Apr 23, 2001 | 06:18 AM
Twin_Turbo's Avatar
The fuel line coming from the rear TB is a home made thingie. http://firewall.geezernet.nu/crossfire/p3081513.jpg
Marck
[This message has been edited by FAQman (edited April 23, 2001).]
Old Apr 23, 2001 | 07:47 AM
super chevy's Avatar
HOT,
For everything Crossfire, go to
http://www.crossfire.homeip.net/
Old Apr 23, 2001 | 08:00 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by HOT/A377:
thanks
</font>
For 325 HP the runner is fine, and this is from experience, and not just repeating stuff. I ran mid 13s with mine.
You need to bore the TB to 2"s, use appropriate injectors, cut the EGR tunnel out, and make a 1/4" spacer to get enough plenum.
Then plumb the TB in pararrel, get enough pump, and run a 747
Fanatic1074
Oct 3, 2022 05:57 AM
3rdgenparts
May 21, 2016 11:50 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
